Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By ScottD3
  • 1 Post By Tom_B
Thread: MFSW + Sports trip tronic wheel = MFTTSW or something.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I was waiting for parts to arrive, RNS-d install to finish and fit my facelift clocks (A small project).
    Now that its all done I can start this project and since its winter it seems like the best project to do during the winter.
    Thanks to Tom_B for the Trip Tronic steering wheel.
    Thanks to @udiA3 for the MFSW from his A6 C5 breaker.
    This all the bits I need/want from the MWFS.
    All of that needs to go in to this.............maybe.
    I'm thinking of putting the buttons here.
    The airbag will need to cut to sink the buttons. On the MFSW will there is brackets that they screw in to. Transferring these over might be a bit of a pain and take up more room, so I'm thinking of bonding them to the airbag. I don't think that's affected when the air bag goes off, so it should be fine.
    Trying to the fit the button control module (I think that's what it is called. I'll find out later.) in side the wheel will be hard and I don't think it will be needed. If I can find the slip ring with the most pins (I need 12 I think) I should be able to relocate the module to the dash but if I can't find a slip ring that has 12 pins I will need to rethink this a little bit.
    I got the radio only relay that came with the MFSW and if I remember correctly I should be fine for now to just control the stereo but future ideas will require the Can-bus unit but I need to double check that.
    The future MFTTSW is blue and I'm not having that. I need to redye the leather and plasti dip the airbag. I think that's the best way but that's something else i can look in to.
    That's it for now.
    I'll have a play with week and let you know how I get one.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Will look good if you get it finished !!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    The slip ring wont have 12 pins, thats why the modules in the wheel. It takes all the switch signals and joins them together.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    There is only one pin difference between keeping it in the wheel and outside.
    Do you know how many pins some of the slip rings have?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Doing a little bit more research on slip rings and reading the info on this post Slip Rings..
    It would seem I need this ring.
    1J0959654MRETURN SPRING WITH SLIP RING AND STEERING ANGLE SENSOR FOR STEERING WHEEL WITH TRIPTRONIC CONTROLS.
    I'm basing this on counting the pins on the slip ring.
    4B0951543B
    RETURN SPRING WITH SLIP RING FOR MULTI-FUNCT. STEER. WHEEL FOR STEERING WHEEL HEATED. Only has 5/6 pints.
    1J0959654M
    RETURN SPRING WITH SLIP RING AND STEERING ANGLE SENSOR FOR STEERING WHEEL WITH TRIPTRONIC CONTROLS. Has 10 pins.
    I doubt very much there is a 10+ pin slip ring out there. As most extras would be using canbus which is only 2 cables and 2 power cables.
    One thing I did not think about yesterday was power and illumination. Both buttons will need the normal 2 power cables and 1 for illumination, I guess. that's 3 cables gone already, so I should only need 9 pins. which works out right.
    I need to sit down with the wiring diagrams later and double that.
    I'll do that and report back.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I had a look in Elsawin and got a my self a bit confused.
    The MFSW is from a A6 C5 on a 99 plate.
    Had a look on Elsa and it's talking about duel colour cables but theses are solid Red, white, black and yellow.
    Not sure if I missed something.
    Is anyone able to take a look and see what of the 4 cables coming from the MFSW module to the slip ring do or where they go?
    "Stick a V8 in it!"
    15,390
    ETKA doesnt show you the wire colors inside the wheel.
    It just shows the wheel as a function block, including the slip ring, and only shows you the connections between the car and the slip ring.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Ok, so I just need the cable colours/pins from the slip ring to the function block/module thingy.
    EDIT: WTF was I doing looking for inside the wheel, when all I need is the cables that goes from it. Dump ass
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Thanks to Aragorn the correct slip ring part number has been located.
    Part number 1J0959654AL.
    Its a Multi Function, Trip Tronic and heated.
    I wont be getting the trip tronic to fully work at the moment. I need a new selector box and TMC for the auto box. So all that can wait till I replace the box or I get board.
    For now I'll forget the trip but I'll hopefully get the buttons lighting up.
    The multi function side of it I'm trying to set up and test on the bench.
    I think I worked out the labels for the J453 relay.
    5 = Remote cable to pin 11 in the stereo 20 pin plug.
    6 = K line
    10 = Earth
    12 = Positive
    13 = Positive
    15 = Illumination
    18 = MF power/remote.
    The bit I'm a little bit stuck is the cabling for this.
    Elsa lists 2 pin plug for the wheel (I think) but one of them is earth and looking at the unit earth is not part of the plug, its out on its own.
    In the black plug there will be power and remote (I assume) but which is which?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Done
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    With the wiring sorted out on the bench I started to cut the Triptronic air bag up to fit the buttons.
    Several hours later with a sharp knife, a pen and its almost in. Little bit more to take off.
    And its in. Its really hard to get the edge right and curves to match. This is the best I could do.
    The switches fit really in. There is no cutting needed on steering wheel side.
    You can see where I've taken a little bit to much away but its not that noticeable when looking at it head on.
    Several hours later again and I have two in.
    Next is to strip the colour out of the leather, dye it black and Plasti dip the rubber black.
    it looks like the air bag blue colour coating is starting to peel and bubble in place. I need to find away to remove that with out effecting the plastic/rubber underneath to much. I'll have a play with that in time.
    Waiting on a sleep ring to support the needed cables then I can do the wiring on the car side.
    PAULF likes this.
    Jan 2012
    Malton
    279
    You are undoubtably a genius Scott. A slightly eccentric one but nevertheless entirely brilliant. You do realise we are all going to want this in our cars now?
    ScottD3 likes this.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Quote Originally Posted by Tom_B View Post
    Not sure everyone but hopefully it will fit and work.
    I don't think it looks too bad.
    the buttons are not a easy reach but closer than pressing the buttons on the stereo.
    Need to wire everything up now.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I sat down last weekend cleaned all the old dye, oils and other contaminants off the leather ready for recolouring.
    Been looking at this product Leather Recolouring but not sure.
    Anyone got any recommendations?
    I also sat down and stripped off all the old peeling blue rubber coating off the air bag.
    Hopefully I'll plasti dip it this weekend to turn it black.
    I need to strip down the trip-tronic buttons as well.
    Not sure how to do that.
  1. Megs wheel brightener or something else....
    By S3 Rav in forum Detailing
    Last Post: 28th February 2010, 18:29
  2. B6 Sport 16" Alloy wheels
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2009, 17:10
  3. Various faults A6 C5 AKE Quattro Sport Trip 2001
    By Andyb12 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th July 2009, 13:49
  4. A4 1.8T Sport 1997 18" Wheels/Tyres
    By norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2009, 09:08
  5. 3 spoke sports leather steering wheel
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th March 2009, 18:32
