Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    Aug 2009
    Dorset, UK
    171
    Rear Calipers on a quattro
    How is it best to compress rear calipers without the wind back tool? Also which way do you turn it? left or right? When doing this should you crack the bleed nipple to stop dirty fluid getting into the system? If so will i have to re bleed?
    Thanks again guys
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Dont touch the bleed nipple. If theres dirty fluid then it needs changed. You shouldnt need to open the hydraulics to retract the pistons.
    The way the handbrake mechanism works, you need to simultaneously (gently) squeeze the caliper/piston, and turn it. Sometimes you'll get away with just turning it while pressing down, sometimes you wont. You can bodge it using a g clamp to squeeze, and a pair of molegrips to turn it, but it chews up the piston.
    TD5 Land Rover Defender build
    Aug 2009
    Dorset, UK
    171
    When i turn the piston it does not go back is there any way to do this without damage to the piston. I dont want to just clamp it back. There must be a trick or way to get it back in do not want to bodge it. How much pressure do you need push on the caliper when turning it
    Aug 2009
    Dorset, UK
    171
    Can you disconnect the hand break part of the caliper and whined it back from the bolt on the rear of piston
    Aug 2009
    Dorset, UK
    171
    Ok what is the tool called that compresses the rear caliper how much is it and where do you buy it from?
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    244
    It's possible to do this with a Draper brake multi tool. I sawed the teeth off that I didn't need!
    With the brake pads off, re-attach the brake carrier, and then use a rubber mallet or indeed a block of wood to place behind the piston to press against. Lean into the brake piston and using a 1/4" extension bar (don't use latex gloves but leather work gloves), turn clockwise and use force. You can open the bleed nipple as you screw it back in! and close off when fully retracted. While you're there - use a little Lockheed red grease under the dust sleeve. Job's a good un!
    I'd bleed the system as a matter of course with DOT 4-5 fluid for best results.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    1,884
    Rather than muck around just get the right tool it's not that much from machine mart. Right-Handed Brake Piston Wind back Tool - Machine Mart
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,877
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2009
    Dorset, UK
    171
    Thanks guys, I will get the right tool to do the job. Is it correct that the rear pads do not have wear warning cables
    Aug 2010
    2,877
    Yep correct !!
    Aug 2009
    Dorset, UK
    171
    Thanks for all the advice guys, went to Machine mart purchased the wind back tool and did the job easy. The noise was shagged disks and pads. Cheers
  1. rear brakes on a quattro - caliper bolt issues
    By matttrs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2011, 22:42
  2. A3 quattro rear caliper problem
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2009, 12:17
  3. S4 Rear Discs/Calipers onto A4 Quattro?
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2005, 16:59
  4. R32 rear calipers
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2005, 10:17
  5. Audi 80 Girling Rear Calipers
    By Geewiz in forum Handling
    Last Post: 12th June 2005, 15:37
