Chris NottVolks Autos
Results 1 to 10 of 10
Thread: wiper problems
    Aug 2013
    30
    Question wiper problems
    hi there
    my front wipers on my b5 avant have started "jerking" when on the quickest speed.
    i was just wondering if this is likely to be the motor or the relay
    thanks for the help
    otg
    2,163
    Could be the mechanism seizing up, I stripped mine down a few weeks back, cleaned up the spindle and covered it in grease and put it all back together, working better than before.
    Aug 2013
    30
    If it was that though wouldnt it do it at every speed?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    When you say jerking are they stopping slightly at all during the arms sweep? This is what mine started off at, after a while they just stopped entirely mid sweep and would not start again for 10-30 seconds, maybe longer. I was convinced it was relay related. But a mechanism rebuild has it sorted. I think the stopping of mine was maybe a thermal cut out in the motor?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Aug 2013
    30
    They are stopping for half a second or so repeatedly around the whole sweep of the wipers. But only on the quickest speed. But i found last night after i had been using the wipers for a while is pessistant rain the quicker speed worked fine. if it is the motor how do i go about rebuilding it and do i need any parts?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    It's a bit of a ball ache to get the mechanism out. I'm pretty sure somebody did a write up on here, I shall have a little look see.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Oh and by the way that is a gret username!
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Slow wiper mechanism repair
    this is a b6 but almost identical for a b5
    Aug 2013
    30
    Ok cheers. And the username was my nickname at work when i "abused" a customer
    Jan 2012
    Malton
    279
    I did this recently and I think the B6 has more room in the scuttle so I had to release the motor from its bracket and wiggle the wiper mechanism out.
    The wiper motor is very torquey and get move the wiper arms even when the pivot bearings are almost seized. My wipers just stopped working within a couple of weeks and I needed to replace the mechanism with a s/ h item from eBay.
    You might find it useful to take pictures before you dismantle so that you have a guide when you put it all back together again.
    I am not particularly intuitive with engineering stuff so while I got the wipers sweeping the correct area of the screen I did not realise that the stop point is defined by the motor so the actuating arm must be refitted horizontally to get the stop point right. ( I put it all back together wrong and had the wiper blades stopping six inches too high.....)
    I found it useful to tighten a couple of zip ties on the shafts to double check the reassembly.
    I bought a wiper arm removal tool which for me was essential to get the arms off without damaging anything. Watch out for damaging the fine conical splines on the wiper arm shafts and when refitting the arms tighten them down enough.
    I did get it all back right in the end and it all works fine.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
  1. Help Needed- Rear Wiper problem.
    By 1.8JT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2007, 15:46
  2. wiper problem
    By a4singh in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2007, 18:04
  3. Rear Wiper Problem
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 20:40
  4. Rear Wiper Problem.
    By imported_Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2005, 14:21
  5. rear wiper problem
    By azures3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2005, 17:29
