Chris NottVolks Autos
    Dec 2012
    20
    Quattro Conversion
    Hi guys. I'm just wondering if my fwd b5 a4 has the mounting points for all the quattro drive train. Has anyone converted a fwd model to quattro? Been offered all the kit and wonder if it able to bolt straight onto my fwd. just need to know if all the mounting points are there before I go ahead
    thanks in advance
    dave
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    nope,the fwd has a totally different rear floorplan to the 4wd.Won't be worth the money or effort to do.
    tony
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Not physically possible and not worth it be easier to just buy a B5 quattro swap the bits you want over to it and then back to the FWD the sell the FWD as is !!
    Dec 2012
    20
    Ok. Thanks guys. That's exactly what I needed to know
  1. Quattro Conversion
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2012, 15:23
  2. A3 1.8T Quattro conversion to KO4 HELP
    By a3-ams in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2011, 10:52
  3. quattro conversion???
    By tangerinedream in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2011, 12:13
  4. QUATTRO CONVERSION
    By GoSPeeDxRaCeR in forum Handling
    Last Post: 9th July 2004, 00:16
  5. A3 QUATTRO 5 TO 6 SPEED CONVERSION
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2003, 23:16
