Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Nitro
Thread: Strange noise 2,8 quattro
    Aug 2009
    Dorset, UK
    171
    There is now a noise from the rear of my car when i break you can hear a repeating noise from the rear. Also when you turn to the left round corners the same type noise can be heard. Can't hear it in straight line when going along, but can year it faintly when turning to the right or loudly when going to the left. Is it wheel bearings or something else. The rear discs are passed their best but the pads are ok. Is it discs or wheel bearing or both.
    Thanks for any advise guys
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    If its when braking then it will be brake related check the back plate and pads try greasing the pads and check the pad springs and also check for any play in the wheel bearings or any foriegn objects near the back plate or in around the caliper/carrier !!
    Also if the disc are corroded and lipped check its not catching the pad backplate if the pads are quite low
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jul 2011
    wiltshire
    121
    I had this problem on my quattro, turntable out to be a mix of warped disks and sticker callipers,
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    The fact it changes when you turn suggests theres wheel bearing involvement to me.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    Yeah, if the wheel bearing is hanging off, when you press the brakes, the first thing that has to happen is the disc needs to be pulled straight, that could lead to a noise. Jack it up safely and have a peak
    Aug 2009
    Dorset, UK
    171
    Thanks guys, how easy or hard is it to change rear discs on a quattro? Fronts are simple, never done rears on a Q.
    If it is rear wheel bearings how are they? Can it be done at home or do i need a press etc?
    cheers
    Aug 2010
    2,889
    Rears are fairly easy, you will have to remove the caliper carrier to get the disc free and you will need a wind back tool to push the caliper back, or if you dont have one sometimes depending how seized the caliper is you can use long nose pliers and push the piston whilst turning it the correct way !
    Aug 2009
    Dorset, UK
    171
    Thanks for this, which way is the correct way to turn the caliper back? (anti-clockwise) is what I would guess.
    "Stick a V8 in it!"
    14,949
    Clockwise i think. Just imagine your using a screwdriver and are trying to screw it in.
    Aug 2009
    Dorset, UK
    171
    Ok what is the wind back tool called where do you buy it from and how much is it? My f*@king car is on blocks and unable to move now. (the pistons turn but do not go back - are they shagged?)
    Aug 2010
    2,889
    No you just need to apply more pressure/force make sure its going the right way, which is clockwise !!
    Aug 2009
    Dorset, UK
    171
    Thanks for all the advice guys, went to Machine mart purchased the wind back tool and did the job easy. The noise was shagged disks and pads. Cheers
    rustynlc likes this.
    Jul 2011
    wiltshire
    121
    Quote Originally Posted by Nitro View Post
    glad you sorted it mate, it's surprising how much noise shaved disks make
  1. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  2. 3.0 quattro-Strange noise
    By Grae in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st October 2007, 18:49
  3. Strange Noise - Sounds like BOV
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 22:52
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
  5. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
