Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By aragorn
Thread: Parking brake dash light
    2,170
    When checking the car over after the dashboard refit, I found the parking brake light was not coming, even during the instrument cluster check at startup. Can someone confirm this light does come on at startup even with the hand break off. Car is a 99 facelift model.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    No, it only comes on with the handbrake.
    B5NUT likes this.
    TD5 Land Rover Defender build
    2,170
    Thanks will test the wiring and switch, could not find anything in vcds to test and see if the light works
    2,170
    Found the fault, someone at some point must have had the handbrake out and rather than unplug the connector it was a better idea just to rip the wires out then shove them back in and hold in place with a bit of tape..... Just confirms why I would rather do the job myself.
  1. Audi a4 b6 parking brake applied light on
    By Quartzlite in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2012, 06:28
  2. Dash lights...abs...brake....oil lights flashing
    By vw754 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2012, 16:28
  3. Replies: 2
    Last Post: 2nd March 2011, 12:01
  4. Warning lights - the ABS and the parking brake light
    By vij31 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th March 2006, 16:10
  5. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
