Sky InsuranceEM Tuning
    Jan 2012
    9
    A4 2.8 30v Timing Belt Change
    I've got a coolant leak which i think is coming from the either the water pump or thermostat housing (until i get the car up on ramps i can't get a good look at where its starting).
    So from reading on here that i have to get the belt off to change the both or either of these i wondered what everyone advised should be changed once its in bits.
    Belt
    Tensioner
    Thermostat and gasket
    Water Pump (possibly if its leaking or is it worth doing anyway?)
    ...anything else i should do whilst i'm there?
    Jun 2012
    43
    Do the water pump anyway, you DON'T want to have to do that job twice.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Water pump is a no brainer for the reasons in your post.
    Remember you will need the proper locking tool to fit the belt, and get the full kit that replaces everything.
    TD5 Land Rover Defender build
  1. Cost of timing belt change A4 B6 TDI 130bhp
    By Andy D in forum General Chat
    Last Post: 28th February 2008, 08:50
  2. v6 timing belt change
    By bigdavie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2007, 16:48
  3. Timing Belt change
    By enda1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th October 2007, 14:19
  4. Timing belt change
    By enda1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2007, 21:23
  5. timing belt change
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 11:42
