JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    How to te activate key
    Lads, I've just replaced the batteries in my key fob, and now the central locking will not work. I do not have the spare key. Question is, is there a way of doing it with just the one key?
    May 2012
    RETFORD, NOTTS
    1,753
    VCDS, or ask me nicely for a spare key :D
    Where are you based?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Hi bud, thanks for the reply, I'm in Truro Cornwall. I don't have a spare which sucks!! And no doubt vag will ask a fortune. Would any spar vag key do? If so il just go robbing from the scrappy?
    Jun 2012
    43
    Unlock car with the key in the door, put the key in the ignition but don't start it then hold the lock or unlock button for a few seconds. That's how mine pairs back up anyway.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Iirc you unlock the car with key put ignition on, press and hold lock button then press the lock button on the drivers door the press the unlock on the fob and it should work the central locking !!
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Nah non of that has worked guys
    Jun 2012
    43
    Quote Originally Posted by Bradderz_1988 View Post
    Haven't heard that and I work for Audi! We advise the ignition procedure, the one you described I believe works if you have 2 keys in the absense of VCDS/5051. The ignition process is for older keys and only works with some flip keys I believe.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    Theres two different procedures here.
    One resynchronises a KNOWN key to the car, for example after a battery change.
    The other pairs an UNKNOWN key to the car.
    the procedure for a known key is:
    Remote Control Synchronization
    • Press any button on remote control.
    If vehicle does not respond by locking or unlocking:
    • Lock and unlock vehicle within 30 seconds using driver-side lock.
    • Now check function of synchronized remote control.
    TD5 Land Rover Defender build
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    I'm close, when I do the 2 key method, I take the key out of the drivers door and the fob then unlockes the car, but does not then lock nor unlock it after taking the other key out the ignition?
    May 2012
    RETFORD, NOTTS
    1,753
    "Stick a V8 in it!"
    15,381
    You dont need a key in the ignition to rematch a paired key.
    That rosstech link discusses pairing up new or unknown keys, it shouldnt be required after a battery swap on an already known key.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    The key is already known but the car, I just need it re syncing. As said I got the fob to unlock the car with the 2 key method, however that is as far as I got and the fob wouldn't work again
  1. How do you Take the circuit board off the Audi Key
    By powersurge in forum General Chat
    Last Post: 10th August 2012, 12:09
  2. How to get second key to work??
    By claytow in forum A8/S8 forum
    Last Post: 17th March 2011, 18:39
  3. help - how to release removal keys (audi concert)
    By xeryus in forum In-Car Entertainment
    Last Post: 9th September 2010, 23:28
  4. How to increase Remote key disstance.
    By imported_norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2005, 19:13
  5. how many keys should i have?
    By imported_druggie in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th July 2004, 19:41
