JMB RetrofitsBadger5
Results 1 to 21 of 21
    Jul 2007
    341
    Snub Mount - 1.8T
    Ive got to do a load of jobs at the front of my A4, and I'm thinking of pulling the front into 'service position' to make it easier. Whilst I'm at it, I want to fit a new snub mount.
    I'm thinking of going for somthing firmer than standard, so my question are;
    - what have people here got?
    - where did you get it?
    - is it worth it? or should i just fit a new OEM quality one (lemforder or meyle etc).
    Ta!
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    RS4 ones are a bit sturdier/thicker and arent that expensive from Audi.
    Or you can go for various polyurethane ones.
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I have a 034 red one and bracket but need to do the engine mounts as there goosed i think so cant really comment fully but it did make a difference !! Got it from hektor at WOT motorsport !
    East Berkshire
    178
    when some work ( cambelt for starters ) was done on 'her'1.8TQS I got them to fit a new RS4 one. Think it was about £12 and of course it looks stock !!
    Can't say I noticed much difference, but along with an engine mount it has to help after 13+years and 85k miles !
    Rear diff and possibly gearbox mounts may be next !
    ChrisG
    Jul 2007
    341
    Thanks chaps, RS4 item it is then - like to keep things OEM.
    2003 VW Golf GT TDi
    2,180
    All my engine & gear box mounts were well passed goosed, but that was after 14 years & 270K miles the gearbox mounts were in the worst condition.
    Aug 2010
    3,138
    Yeah the gearbox mounts detached from the housing on mine !
    Jul 2007
    341
    What was the effect of the box mount failing?
    still chasing a thud when I let off the throttle - front diff mount is my next target.
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    Yeah was thudding i still get it but havent done the engine mounts yet there on the to do list as soon as the rear diff issue is sorted as there the only mounts left to do then its subframe bushes front and rear !!
    "Stick a V8 in it!"
    15,388
    i replaced everything chasing that thud and only made it worse
    It seems theres a few causes, so sometimes you'll get lucky with the mounts, in my case its some sort of drivetrain slack, which simply became more and more obvious as i tightened everything up.
    Aug 2010
    3,138
    Ive also thought the same thing but my engine does move alot so going to do them along with the subframe bushes the only other thing i could point it to is the prop but dont fancy the price of the 034 one-piece prop lol
    Jul 2007
    341
    Got an RS4 snub mount here ready to fit.
    It was mentioned (by Bradderz I think) in another thread that you dont need to remove the front end to do this. How is best to do this?
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    Jack up car remove the snub bracket bolts and slide over snub towards bumper, knock off old one, knock on new one bit of lube will help, i had to jack the engine a little on mine by removing lower engine mount nuts (2x 13mm) but i fitted 034 snub and bracket so was tight for space as bracket has no opening to slide over snub, then bolt mount bracket back up, jobs a good un !!!
    Jul 2007
    341
    Awesome - thanks. did you undo both engine mounts to lift the engine?
    Just to clarify, I only unbolt the alloy snub bracket from the front of the engien, and then push it all the way over the snub towards the front of the car. I should then be able to get the old one out.
    Sounds good to me! a lot easier than taking the entire front off.
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    Yes and yes !! correct !!
    Jul 2007
    341
    Cool, will give it a go one night this week.
    2003 VW Golf GT TDi
    Jul 2007
    341
    Gave this a go last week, didnt really go to plan! lol
    Jacked the car up, under tray off, unbolted snub bracket, popped the old snub out with a screwdrive and a bit of force, turned out it was split down one edge, and Id split it a bit more levering it off. There was no way the new one was going in though, even with the engine lifted. In the end the front end came off and I did it the traditional way, doesnt take too long but a lot longer than planned!
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    May be easier on a 2 post then !!! Glad you got it on in the end !!
    Jul 2007
    341
    haha yea. Yup, its all sorted and made a difference to how it drives.
    Also replaced the vac hose to the diverter as it was almost worn through - looked perforated before. It definitely goes better now but did hold boot OK before. Using Sytec vac hose, which is black with a cotton over braid like the original Audi stuff, but has about twice the wall thickness and is actually sold as fuel line, so should be a bit more resistant. A nice OEM looking replacement.
    2003 VW Golf GT TDi
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    180
    I presume from the post above that the RS4 mount will fit on the 1.8T AJL engine ? Does anyone have the part number for it?
    Jul 2007
    341
    yup - RS4 snub mount onto an AJL 1.8TQS. was about £10, its considerably more strudy. cant help on a part number though.
    2003 VW Golf GT TDi
  1. Snub mount
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2008, 10:25
  2. Snub Mount
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th March 2008, 22:46
  3. APR snub mount
    By enda1 in forum Awesome GTI
    Last Post: 25th October 2007, 14:51
  4. APR Snub mounts in UK
    By dan1 in forum Tuning
    Last Post: 25th October 2005, 16:52
  5. Engine Snub Mount
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 07:44
