cbass
- Joined
- Nov 19, 2003
- Messages
- 144
- Reaction score
- 0
- Points
- 16
- Location
- Orem, Utah, USA
- Website
- www.netdocuments.com
Hey guys,
Today, I was just driving the car around and it all of a sudden just died. All the gauges stayed lit, radio stayed on, climate control stayed on, etc. But the engine just died, could rev it, couldn't do anything, the tachometer needle just slowly settled down to ZERO. I pushed it off to the side of the road and called a friend to come pick me up. I waited about 5 minutes, and then tried to start it again. It started right up so I called my friend and told him I'd try to get it home. It went for a few miles, and then died again. I waited a minute, and it started fine. It did this all the way home, died, started, died, started, etc. When I got home, I plugged in the VAG-COM and got these codes, none of which were there just two days ago.
7 Faults Found:
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-00 - -
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-00 - -
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-00 - -
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-00 - -
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 35-00 - -
If any of you have any ideas on what may be causing these, please help! I have looked through the Bentley manual, but to no avail.
TIA! /ubbthreads/images/graemlins/beerchug.gif
7 Faults Found:
P1237 - 35-00 - -
P1238 - 35-00 - -
P1239 - 35-00 - -
P1240 - 35-00 - -
P1425 - 35-00 - -
P1547 - 35-00 - -
P1472 - 35-00 - -
