Results 1 to 20 of 20
    boost-addict's Avatar
    Aug 2011
    977
    need help with my abs module
    right so when i bought the car (which i wish i didnt) it had a abs light on and was told its a abs sensor, so bought it and the rest of the car has only given me minor issues as normal, other then the clutch which is being sorted.
    so problem i have is i sent off my module but apparently never got there, and the recorded tracking showed no one signed!
    so i am now left and have been for the passed 6 months with no abs module. i did take note of the part number which is
    0 273 004 284 i have it saved as a saved search and the only ones that pop up are from usa. and new ones are WELL out of my budget. altho it may just have to be a new one!
    so can any one tell me what ones will fit and would i need full vcds or would a registered lite work. i dont have any coding obviously as the module would lock vcds out. so what can i do as mot is up in march and ive been looking and looking
    and i really need to get it sorted a. because winter is coming up and b. as itll fail the mot.
    i understand you cant disable the abs and have new brake lines routed to cut out the abs system. which i wouldn't want to do but they work with out fault any way
    basicly HELP!!!!
    Jan 2011
    Aberdeenshire
    629
    I had similar problems finding a module.
    However, I did find there was a module number - from Bosch - which you have, but also a pump assembly number from Audi (8E0614111B is an example) I found there were many more pump assemblies than modules for sale, and the cost was about the same
    You need to get the correct number for your car - if you have Elsawin there is a table of pump numbers against car model so you can get it there. (My copy is playing up, sorry)
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    May 2012
    RETFORD, NOTTS
    1,707
    also depending where abouts you are there is bound to be a local member able to code the module in for you if its needed.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Module doesnt need to be coded, it just plugs in and works.
    Your best off looking for whole pumps ending in A or E, and swapping the module over.
    They're used on a few cars like the A6 and A8 as well as the A4. It must be from a quattro and must be pre-ESP. If you stick to looking for pumps ending in A or E you should be fine.
    TD5 Land Rover Defender build
    Aug 2011
    977
    Oh really!! Ok so a4-a6-a8 pumps ending in a and e..
    If i get a few together can i link them to you and you tell me yes or no.
    Oh on a side note got the fly wheel going to the machine shop this month.
    "Stick a V8 in it!"
    14,907
    yeh just match the part number, if it matches it'll work.
    Aug 2011
    977
    this is the problem ive been having mate.
    the only info i have is the part number from the module 0 273 004 284
    and obs the part number on the pump
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Try 8E0 614 111 A or 8E0 614 111 E
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Aug 2011
    977
    thanks, looked on ebay..... ha, presume you havent seen the modules that aint on there,
    theres one but £240, why i dont know
    Audi A4 ABS Pump And Controller - 8E0614111A - 8E0 614 111 A | eBay
    other then that its a return and replace which clearly i dont have! but then reading the ad, its got hidden charges writtten all over it
    Aug 2011
    977
    just emailed and asked why it was £240 etc
    this is the reply
    hi its down to availability and how scarce they are i am the cheapest on ebay for this model
    i hope this answers question
    Aug 2011
    977
    so making it £100 more just becasue there few and far between!
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Just keep looking, I sold one for £40 because that's what I thought it was worth.
    might be worth checking SRS classifieds as a couple of S4's were/are being broken
    Aug 2011
    977
    ah right ok
    yer been looking for breaking a4s too
    now you understand my pain!
    Jan 2011
    Aberdeenshire
    629
    It took me a while to get mine, I can't remember what I paid in the end but I think £50 or less.
    (Mine was a 8E0 614 111 E )
    Try a few scrappies too - the bay of 'E's is starting to get a bit rubbish for finding stuff
    Aug 2011
    977
    right, found one, £93 and £21 postage from usa.
    apparently its a rebuilt re-manufactured unit and has a lifetime warranty.
    but is it the right one!?
    ABS Module for Audi A4 A6 VW Passat 0273004284 8E0614111A Only $100 after swap! | eBay
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    That's the one. Have you mailed him to check its ok not to return a module?
    Aug 2011
    977
    well he says:
    • You may not purchase this listing without an intention to return a functional core.
    but it says $150 (£91) so if you was returning a module it would be $100 (£61)
    but what would you do?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Personally I would let him know the situation with your module being lost and see what he says, it may be that he only has a small turnover of these units and would probably be quite miffed with being down a unit. But ultimately it's your call
    Aug 2011
    977
    i dont want to do an one over, id be pissed if some one didnt send me back a module
    but on the other hand i dont wanna loose this by him closing the door on me
    really dunno if to be considerate or selfish !!
    im not a selfish person so dunno.
    unless i email him from an other account and say what happens if i dont have a module
    Aug 2011
    977
    ok went back though my service paperwork etc, as i know lynx services replaced the module in 2009, i didnt actually see this the first time, but have a receipt for £300 for exchange abs unit 0273 004 284/X
    company
    lynx automotive ltd
    nottinghamshire
    also on a plus side discovered it had a oil pump fitted 35k ago! bad news is ive realized i have cam belt due in 600 miles lol
    any way still on the hunt for one any people know any more suggestions?
  1. Need help with power tool
    By Defratos in forum General Chat
    Last Post: 15th January 2007, 17:37
  2. Need help with latest interior mod!
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 11:59
  3. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
