Sky InsuranceEM Tuning
    gmx
    Feb 2009
    Sydney
    132
    ABS Intermittent fault - VAGCOM no response
    Ok, I know this is most likely the ABS module itself (the code was specifically, "intermittent electrical fault between cluster & ABS module).
    BUT, a BIG BUT, I cannot access the engine module via VAGCOM to check for codes/take logs.
    This is the second B5 I have seen with such a problem. Roughly 3-4 years I vaguely remember trying to VAGCOM a friend's car and his ABS module was intermittent, in the middle of logging it would lose connection to the engine module if the ABS fault came on.
    Has anyone else experienced this?
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    I haven't, but I'm sure I read before about it, I think that they disconnected the module prior to the scan as I think it's signal overpowers/corrupts the Kline. Got to be worth a go for the sake of a plug.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Its not unheard of that when the ABS module dies, it jams the K-Line.
    Try pulling the electrical plug out of the ABS module and see if you can communicate with the ECU/Cluster
    TD5 Land Rover Defender build
    Oct 2012
    385
    i have seen this before and it's not unusual at all, time for abs module repair
  1. ABS Throwing fault Wheel Speed Sensor
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2009, 15:15
  2. Intermittant fault, engine won't crank
    By KennyBradley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd October 2006, 10:50
  3. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
  4. J(92) Audi 80 Sport Intermittent fault
    By clarkee123 in forum Classic Audi Forum
    Last Post: 17th November 2003, 21:44
  5. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
