Monster MotorsportChris Nott
Results 1 to 7 of 7
    Nov 2012
    22
    Temerature Problem ???
    Hi guys just recently my temp gauge is showing some worrying signs.
    Normaly it stay's at 90 degrees Normal op temp
    But in the last week it is creeping over the 90 and up to 100 105 degrees im not sure why. When I Stop then the fan comes on any ideas
    Coolant is fine do you think it might be a sign of the thermostat going ???
    Jul 2007
    770
    Unlikely cos tne stat should fail open which would not cause overheating.Probably the waterpump is going
    Nov 2012
    22
    mmm actually I think now I have been having water come from my car on the floor but I thort this was the air conditioning unit ?? if it is my ater pump why has the coolant level nto dropped ?#
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Be sure that yu don't have any air in the system, mine shot up over 100c when I hadn't bled it properly
    Currently rolling in a SKODA!!!
    Nov 2012
    22
    I have no air lock in the system im going to change the thermostat as im sure this is the problem
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    failed water pump sounds plausible.
    Mine worked fine if the revs were low, but bring it up past about 2-2.5k and the pump impeller would start slipping on the shaft and the temp would shoot up. slow down or stop and the impeller would grip again and temp would drop back down.
    TD5 Land Rover Defender build
    Nov 2012
    22
    Aragorn this is exactly the problem m8y ive got a day off work today so im going to have a look
  1. Transmission Problems
    By MisterD in forum General Technical / How To
    Last Post: 3rd February 2003, 13:23
  2. Ooo eck I've got a problem!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 13:12
  3. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
