JMB RetrofitsBadger5
    Oct 2009
    190
    Fitting boost gauge on FL
    Such a simple job on my old PFL to fit a boost gauge but with this damn FL with air con and more gubbins in the dash what's the easiest way to run it through?
    last time it tapped into the stereo can I just use the vent wires now? Baring in mind it's a smoked gauge so would I need the lights on to see it.
    cheers all
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    I spliced the switch feed in to the vent wires iirc and run the live to the nut and bolt connections under the relays with a crimped ring terminal.
    Piping runs through grommet below brake servo pipe iirc then through ecu box and up to centre vent drilled a hole size of piping in side of vent duct to boost gauge.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    yeh i cant see why facelift would make the routing any different, just go thru the ECU box like normal.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Mine's taken through the fuse box and the feed from the buzzboard under the relays. Just installed an in line fuse to makes sure if anything goes pear shaped it's protected.
    Life begins at 140mph
    www.passionford.com
  1. fitting boost gauge to my audi a3 turbo
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2013, 20:03
  2. Fitting boost gauge
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2011, 00:33
  3. APR Boost Gauge Fitted
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2004, 08:22
  4. If i fit a boost gauge - Will it void my warranty?
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 14:29
  5. Fitting a boost gauge
    Last Post: 24th May 2004, 22:01
