Thread: steering vague
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    steering vague
    ive been driving up and down from Worcester to Sheffield motorway a few times this week and i have noticed that my steering feels vague when driving around 50-70 mph.
    the wheels were balanced week or so ago and the alignment was also done, i don't drive on the motorway as much as i used to so this is the first time i had chance to notice it.
    when im cruising along the car seems to wander a bit and i keep having to correct the steering but it doesn't feel as tight as i think it should.
    i was thinking of changing track rod ends as they never been changed and car has done 135000 miles but any other ideas?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    Get it proper 4 wheel aligned also check that the control arms etc are in good order, i chased this as my old rack had play replaced the rack still got vague steering but the free play had gone, did a alignment and replaced front tyres and it was fine !!
    although its starting to come back a little and steering wheel is slightly of centre also it changes the direction of being of centre to the camber of the road, if i straighten the wheel it pulls very hard to the left going to sort this weekend along with the bad rear bearing and o/s rear diff seal !!!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    front tyres are only month or so old, control arms are also less than 6 months, audi did the alignment lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Good control arms? or cheap ones?
    If you replace the TRE's, use S4 style solid steel ones rather than the crappy rubbery ones they fit to the A4.
    TD5 Land Rover Defender build
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    they were the good ones as decided i didnt want to spend out twice
    ive just looked on euro carparts website and it lists loads of different ones for the a4 and s4, so how would i know which is best ones
    "Stick a V8 in it!"
    14,900
    Well its just the Meyle kits come with TRE's yet you said you havent changed them...
    Jason at All German will sort you out with some solid S4 type TRE's
  1. Audi A6 100K miles, vague steering and tyre scrubbing on outside
    By ac505 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 22nd April 2013, 19:11
  2. vague steering, out of ideas??
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2011, 14:43
  3. Steering started feeling vague after pothole
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 12:41
  4. Vague Steering
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2010, 18:01
  5. Steering Judder
    By Drystone in forum Other Brands & Models
    Last Post: 6th January 2003, 17:28
