Badger5Volks Autos
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Nut splitter!
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    Nut splitter!
    Iam about to do the old Mr Muscle trick on my AFN but looking at one of the bottom nuts for the flange looks like it will shear or somthing so I was thinking of using u nut splitter and replacing the nut/stud has anyone else used this method of removal to sucess?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Your best off with irwin sockets for rounded bolts you knock them on and they grip into the nut on removal never failed when using them unless one off the sockets dont fit the nut lol !!
    Or you could get the car up to temp and then remove the nut thats fubar and then let it cool down and crack on with the task at hand !!
    PAULF likes this.
    Sep 2012
    Bamfurlong Wigan
    199
    Oh yeah I got a set of Snap On ones for locking wheel nuts on the scrap cars, great tools!
    boost-addict's Avatar
    Aug 2011
    977
    what to do if i have a turbo bolt that undoes half a turn and goes dead tight again, i tightened it back up and left well alone :/
    Sep 2012
    Bamfurlong Wigan
    199
    Quote Originally Posted by boost-addict View Post
    Now thats a sensible man
    Sep 2012
    LEEDS
    125
    Audi A6 C5
    Used a nut splitter to solve my siezed nut problem .
    Then replaced all the nuts including the hot side on the turbo/exhaust .
    I had put wd40 first and also tried tapping a smalled socket but to no avail also tried the blow torch method but still no.
    Just make sure you dont cut all the way to the tread and then turn damaging the thread.
    Good Luck !
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
    Sep 2012
    Bamfurlong Wigan
    199
    What I plan to do (fookin Wednesday now) is get the car up to running temp, then get get the blowlamp on till cherry red, whack on a 6 sided socket maybe size below and try to turn, if it does move a bit and stop i will do the old back and forward method, then if response feels bad ie shear/snap, then comes the nut splitter oh and before, plenty of Plus Gas, it seems to work like magic and walks all over WD40 in my experience, seems to dissolve/crack rust/
    Aug 2011
    977
    Plus gas is good terrible in a tin for most jobs ,,
    Mine feels like its going to sear, so ill leave it till i have a hybrid or bt.
    Sep 2012
    Bamfurlong Wigan
    199
    Whats a bt mate?
    Aug 2011
    977
    Big turbo :D
  1. Lost Locking Nut!!!! Please Help!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 18:34
  2. Require lock nuts.. but these are special :)
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 15:57
  3. Locking Wheel nuts - Which ones?
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2004, 16:33
  4. New A3 and locking wheel nuts
    By Karcsi in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2003, 13:15
  5. cleanandshiney.co.uk for cleaning nuts!!
    By CARACTERE007 in forum General Chat
    Last Post: 9th May 2003, 15:04
