Badger5Monster Motorsport
Results 1 to 9 of 9
Thread: FPR question
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    FPR question
    Looking at upgrading the fuel system on my a6 2.7t, done all the lines, new pump and rs4 injectors on the way, i found a new Fuel Pressure regulator (5 BAR). question is, will it make any difference? will it give me more fuel flow to the engine as a pose to my current 4 bar regulator?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,369
    its a two edged sword.
    First of all, yes, higher rail pressure will allow the injectors to flow more fuel, BUT, the pressure is offset by boost. That means if you have a 4 bar regulator, and have 1.5 bar of boost, the rail pressure increases to 5.5bar. The problem is that the higher the pressure, the less fuel the pump can flow, and obviously your putting everything else under more stress too.
    5 bar static pressure is quite simply far too high. All you'll end up doing is breaking the fuel pump.
    TD5 Land Rover Defender build
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    but if i have a pump to cope and a map to suit?
    "Stick a V8 in it!"
    15,369
    buy larger injectors instead.
    There is NO reason to be running a 5 bar regulator.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    cool, already got rs4 injectors now lol
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    sad time, guy that was selling fuel pump has turned out to be an idiot! so i still need a fuel pump, any ideas as to which one..... ill be running 630cc injectors
    jcb
    Sep 2005
    uk
    4,077
    Bosch motorsport 044
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Quote Originally Posted by jcb View Post
    yeah i looked at them, but arnt they external?
    jcb
    Sep 2005
    uk
    4,077
    no.
    Run them in a V8 cage and filter
    minor modding required
  1. FPR Question...
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2006, 13:15
  2. The Big Question - War
    By Moresauce in forum General Chat
    Last Post: 28th February 2003, 16:10
  3. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
  4. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
