Volks AutosBadger5
    Jun 2011
    73
    coolant pump part no.
    Does anyone on here no the part no. for the coolant pump for a 1999 A4 B5 1.8tqs with AJL engine code and the best place to source one as cheap as possible, as I am looking to replace mine when I do the oil pump at the same time in the next couple of weeks, thanks.
    2,158
    050121010CX but 050121010C will work as X is just for exchange. For the pump try GSF Car parts or Euro car parts, or ebay!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Jun 2011
    73
    Ok,thanks for the help guys, much appreciated.
    jcb
    Sep 2005
    uk
    4,077
    get the one with the metal impeller
  1. abs module/pump part numbers
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2009, 19:39
  2. Continued coolant pump
    By S3BLX in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2009, 20:55
  3. S3 Fuel pump Part Number?
    By jamiebennett81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2008, 22:27
  4. Oil or coolant pump ? once engine switched off ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2007, 23:06
  5. Water Pump part no. request.
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 18:14
