Monster MotorsportEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
Like Tree5Likes
Thread: My 1.8 TQS kindof project thread.
  1. #41
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Quote Originally Posted by crazy88 View Post
    Yeah mine does too. Didn't realise they all did though.
    And yes it's nice it passed on the day rather than needing some work, I'll just get them looked at over the next few weeks (brake lines) and then it'll be all good.
    All tqs's are basically small engined s4's, so black headlining, Ali trim, strut brace etc all standard
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
  3. #42
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    If your thinking about brake upgrades, maybe now is the time, as depending on the setup you choose you may need different rear lines?
  4. #43
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    If your gunna upgrade the rears and leave the fronts as 312's then get S4 facelift vented rears as the TQS brake hoses are the same as the S4 iirc
    Plus if you ever decide to go bigger upfront you then have the S4 rear calipers to do the 300mm upgrade !!
  5. #44
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,802
    What's a price estimate for the s4 facelift brakes? I might take the chance to upgrade them rather than just doing the brake lines. We shall see.
    Thanks for the advice!
  6. #45
    Aug 2010
    3,113
    I got the calipers for £75 posted and new seal/boot kit was about £10-20 and had some hammerite left over so got them all cleaned up on the bench wheel and gave them a lick of paint to clean them up a bit !!
    Just go on SRS and see whos breaking an S4 il have a quick look if your not a member on there !!
  7. #46
    crazy88's Avatar
    West Yorkshire
    4,802
    Cheers for the info bradderz. The rear subframe is looking a little worse for wear also. The mot tester suggested I wire brush it all and protect it. Waxoyl? What do people use for stuff like this? Or should I get a new/refurb subframe? I'm sure at this age the bushes will be worse for wear.
  8. #47
    Aug 2010
    3,113
    Its upto you how you do it either way it has to come off ....
    1. Buy a used frame, clean it up then spray it or get it powdercoated, then fit new bushes and find time to fit it !!
    2. Remove frame then as above clean, paint, new bushes and fit !!
    Just before winter i just cleaned it best i could on the car and used some underseal but may look at doing it properly in the summer when the drive is abit warmer to ly down on if im not in the trade that is otherwise il do it at work on a ramp and stand as im looking at doing the rear bushes pretty soon thinking of poly bushing
  9. #48
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Mine is desperate for it too, I gave it a coat of waxoil aerosol when i had the car, I will probably do this again as soon as car is mobile. Hopefully stop it where it is. No one ever looks under the car, so wouldn't know how scabby it looked,LOL
  10. #49
    crazy88's Avatar
    West Yorkshire
    4,802
    Been looking at braided hoses for when i upgrade the brake lines. Was thinking of this kit; HEL AUD-6-215
    Most sites state that it's avant and don't explicitly state whether the avant and saloon brake lines are the same. Are they?
    Also, anybody used brakes4u, they are a lot cheaper than most other places! (I've emailed them to ask the same fitment question, but I don't always trust online sellers)
  11. #50
    Aug 2010
    3,113
    Avant and saloon are the same iirc
    When i ordered my goodridge hoses and ate blue off ebay i gave them these measurements
    Front: ~330mm with 2x Female ends
    Rear-Subframe to Wishbone: ~190mm with 2x Female ends
    Rear-Wishbone to Caliper: ~255mm with 1x Male and 1x Female ends
    Think there M10x1 thread iirc
  12. #51
    crazy88's Avatar
    West Yorkshire
    4,802
    Cheers mate, very helpful!
    How much were your hoses? From brakes4u I can get the HEL ones for about 85ish, for all 6, which I didn't think was too bad.
  13. #52
    Aug 2010
    3,113
    Mine were around 120 posted for 6 lines and 2 litres of ATE super blue.
  14. #53
    crazy88's Avatar
    West Yorkshire
    4,802
    Ah nice. First time i've done brakes, so might be interesting. I'll be ordering the lines in a bit. Think I might put super blue in too, i've seen it mentioned a few times now...so must be good.
    Thanks again.
  15. #54
    crazy88's Avatar
    West Yorkshire
    4,802
    I'm confused now...
    I enquired about the braided hoses but got no reply, so went about buying the ones I thought were correct. Sods law, about an hour after I ordered a set somebody got back in touch and said that since I don't have an avant, I need one of two other choices.
    It depends on whether my chassis code is pre 8D-V-168-350 of from 8D-V-168-351.
    Looking at my chassis code (vin) in my service manual it's wauzzz8DzXA3....
    Does that mean I'm post 8D-V-168-351? I hate chassis numbers, and I'm on my phone too so using them decoders is a pain in the arse too.
    Any advice?
  16. #55
    Apr 2004
    12,505
    I did away with the small joiner pipe and went direct to caliper from the one flexi
  17. #56
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    I think all tqs are from 8d-x-200-001 as that was the facelift change over, not sure what the "v" is about ?
  18. #57
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Actually I think the v relates to model year, and mine on a 99 is an x, so yeah you'll be post
  19. #58
    crazy88's Avatar
    West Yorkshire
    4,802
    Quote Originally Posted by Broken Byzan View Post
    Interesting! With my lack of knowledge I think i'm gonna keep them as is this time! I don't want to factor more possible failures into this little bit of maintenance! :D
    Quote Originally Posted by Sulli79 View Post
    Cheers mate. I'll give them a ring tomorrow. I'm still not sure what is different between a saloon and avant though...if anything?!?!
  1. Lingo's Audi A3 Project Thread. Warning: Picture-Heavy!
    By Lingo89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2013, 00:33
  2. My b6 a4 tdi 130 sport project thread
    By geoffersmaher in forum The Project Room
    Last Post: 11th September 2012, 20:25
  3. Semi badgered project thread
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 23:07
  4. TT project thread....
    By Welly in forum TT/TT-S/TT-RS Forum
    Last Post: 4th August 2011, 14:10
  5. Link to new project thread....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 15:15
