Volks AutosEM Tuning
Results 1 to 11 of 11
    Mar 2010
    125
    Fault Codes from my Car
    As discussing an earlier thread these are the log readout for my car.
    The engine has been out, due to blown turbos which i replaced
    as i said the units are firing up but not past 0.5 bar and the boost doesnt always hold, naturally the faults standing out are the boost pressure control valve and the purge valve, have i done something wrong :-(
    11 Faults Found:
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 35-00 - -
    17938 - Cant Find
    P1530 - 35-00 - Please Register/Activate
    17955 - 17955/P1547/005447 - Boost Pressure Controle Valve (N75): Short to Ground
    17697 - Boost Pressure Control Valve (N249): Short to Ground
    P1289 - 35-00 - -
    16486 - 16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    17861 - Cant Find This
    17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
    P1457 - 35-00 - -
    17523 - Cant Find This
    P1115 - 35-00 - Please Register/Activate
    17527 Cant find this
    P1119 - 35-00 - Please Register/Activate
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    16538 - 16538/P0154/000340 - Oxygen (Lambda) Sensor B2 S1: No Activity
    Mar 2010
    125
    I have listed the codes i can find, go i am so depressed, if anybody can help me as to the possible reason for the limp mode, or if one thing is related to all others etc?
    May 2012
    RETFORD, NOTTS
    1,753
    Id like to see a vcds scan, where abouts are you?
    checked all wiring and connections ?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    jcb
    Sep 2005
    uk
    4,077
    are you absolutely sure you replaced all the connectors and earth straps
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I'd be checking the earth strap behind the coolant bottle.
    You did clear all the codes when you first got the car started after your engine pull didn't you? You always end up with a shedload at first.
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    Given so many faults then i'd imgine its either a missing/broken earth, or perhaps some loom has chafed thru or similar, or a blown fuse even.
    The codes arent shown as "intermittent" which means they are still present, rather than historic.
    TD5 Land Rover Defender build
    Mar 2010
    125
    yes i cleared all the codes, and then i went for a drive and got them all back again :-/ , really depressing me, i will check the fuses in a bit, i am guessing there the Engine Timing Fuses
    Mar 2010
    125
    Quote Originally Posted by @udi A3 View Post
    I am in leeds mate
    Mar 2010
    125
    Id like to see a vcds scan, where abouts are you?<br>
    <br>
    <br><br>I am in leeds mate
    Mar 2010
    125
    well a pesky fuse has me out of limp mode, so will rescan in a bit to see what faults have now, but were boosting like a mother!!!
    May 2012
    RETFORD, NOTTS
    1,753
    im only 40 mins down the A1, if you need a scan or second pair of eyes, give me a shout.
  1. Bad car Any suggestions? Fault codes
    By richieski in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th May 2013, 21:20
  2. Help with Air conditioning fault codes from VCDS Please.
    By Matt 77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2011, 20:30
  3. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
  4. Cant get a reading from my car
    By shamtec in forum General Technical / How To
    Last Post: 16th October 2003, 22:31
  5. Cant get a diagnostics from my car
    By shamtec in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2003, 13:37
