Results 1 to 14 of 14
    Mar 2010
    125
    Testing Dumpvalves
    Is there way to test if DV are failing?
    I have fitted a Boost Gauge as i was sure my car wasn't boosting fully, and i can now see that its getting to about 0.5 Bar or under and cant hold it, i have checked and listened for leaks, i also disconnected the MAF in case that was been a divvy, so i am now thinking DV's ? they are the originals and have covered 164,000 and are 15 years old.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Pull them off and blow through the side port if you go red there fine if you can blow through it replace them !!
    S4 Muzza's Avatar
    oww! my giant blue head!
    May 2011
    Ayrshire
    306
    Use a pen or something to push the piston up from the bottom and cover the top hole with a finger. If the piston stays where it is all is good, if it slides down its not holding pressure.
    bulletproof methodology.....
    Audi S4 (B5) - JUST ARRIVED :D
    Audi S3 (8L) - GONE
    Audi A3 SE (8L) - GONE
    Mar 2010
    125
    so i tested my DV's and i push them to the top cover the hole and they drop about half way back down, then i let my finger off and they plop totally back down, so i am guessing they work, or should they stay right at top and not come down at all?
    My Boost gauge shows vacum 0f about -7 -8 on idle.
    i cant hear any leaks so i am totally stumped :-(
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Have you scanned the car for faults? It sounds like limp mode. I assume you have a 2.7?
    Mar 2010
    125
    no just downloaded the VCDS Lite so i will try a scan later
    yes it is a 2.7 Bi Turbo
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    smoke test
    Mar 2010
    125
    not sure what you mean by smoke test, if your refering to if my turbos smoke at all they dont, i get nothing out the back of the car other than the usual :-)
    S4 Muzza's Avatar
    May 2011
    Ayrshire
    306
    smoke test puts smoke through the whole system, so you'll be able to see easily if there are any leaks. Not sure exactly how this works myself, but i think you can pick up a kit for £30/£40??
    Not for the correct car but should give you some idea
    HOW TO BOOST LEAK TEST on an AUDI A4 1.8T - TurboBoostLeakTesters.com - YouTube
    Audi S3 (8L) - GONE
    Mar 2010
    125
    well as i put on a new thread these are the faults i got
    As discussing an earlier thread these are the log readout for my car.
    The engine has been out, due to blown turbos which i replaced
    as i said the units are firing up but not past 0.5 bar and the boost doesnt always hold, naturally the faults standing out are the boost pressure control valve and the purge valve, have i done something wrong :-(
    11 Faults Found:
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 35-00 - -
    17938 - Cant Find
    P1530 - 35-00 - Please Register/Activate
    17955 - 17955/P1547/005447 - Boost Pressure Controle Valve (N75): Short to Ground
    17697 - Boost Pressure Control Valve (N249): Short to Ground
    P1289 - 35-00 - -
    16486 - 16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    17861 - Cant Find This
    17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
    P1457 - 35-00 - -
    17523 - Cant Find This
    P1115 - 35-00 - Please Register/Activate
    17527 Cant find this
    P1119 - 35-00 - Please Register/Activate
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    16538 - 16538/P0154/000340 - Oxygen (Lambda) Sensor B2 S1: No Activity
    Apr 2004
    12,521
    At least 3of them would cause limp mode. Especially 02 sender egt and maf. I'd check fuses because an awful lot of fault s there that bi believe share a fuse.
    Mar 2010
    125
    Quote Originally Posted by Byzan Pics View Post
    what if i have got the earths wrong, as in ones on engine should be on chassi and vice versa, or would that not matter?
    Apr 2004
    12,521
    shouldnt do no, as long as the body is connected to the engine it should be ok. I assume you havn't perhaps trapped a wire in between anything when you had engine out?
    Mar 2010
    125
    well i dont think so i will have to have a good check over
  1. Test Drove New A3
    By dbm in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 23:21
  2. TTC180 road test results anyone?
    By Mikiew in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd June 2003, 20:51
  3. Tested ... 220km/h for A3 2.0 TDi
    By roberto in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2003, 04:58
  4. Lemans Motorsport Dumpvalve
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2003, 20:24
