Volks AutosBadger5
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Making your own EGR blanks?
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    Is it possible to do the above, I have sheet ally thats about 5mm thick and flat and true, will this work, its not that Iam being tight, I want to do this job maybe today, I thought I could use a jigsaw/hacksaw and drill, also waiting for the Ebay ones etc, just wondered if the ally will be up for the job, its very sturdy gear (its my old road sign lol When I say "today" I mean theoretically as Iam awaiting to purchase the PD130 manifold.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    You could used a coke can ?????? lol
    have used one to rule out a faulty egr before now !!
    PAULF likes this.
    Sep 2012
    Bamfurlong Wigan
    199
    Love it! £$kin Coke can LOL excellent, thanks for the info
    Sep 2012
    Bamfurlong Wigan
    199
    Surprise bloody Surprises!!
    As I was checking my oil today, I was taking a general look over the engine as Iam going to Gunk it (clean it) anyway I was also looking carefully at what I had to do to do the EGR blank, then when I looked closely at the top joint of the EGR hose its already been blanked with some say about1.5mm sheet steel (very neat I must add) but everything has been left in situ ie EGR valve the suction hose etc so is it ok to leave it as such or do I need to complete remove the lot hose, EGR etc or will it make no difference, I couldn't believe my bloody luck, I also looked at the air filter and it looks CHOKKA! blocked so a good service should help in a big way hopefully
    Sep 2012
    Bamfurlong Wigan
    199
    Just a quick question which iam sure it wont matter, would it be ok to leave all the EGR gubbins in situ know I know that its been blocked?
    Cheers Ste
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    its fine to leave it in place even if its blanked.
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Jul 2007
    London
    3,250
    Coke can would not last long enough, the alloy is too thin and it will burn trough + you don't want melted blobs of metal injected in the engine ! As above, you can leave the EGR pipes on the car for stealth look but best is to remove altogether and simplify the vacuum layout ! Get that EGR delete pipe and pd 130 pipes in there...
    FOR SALE:
    Sep 2012
    Bamfurlong Wigan
    199
    Willdo do ASAP matey, soon as I know how my uncle turns out
    Sep 2012
    Bamfurlong Wigan
    199
    Cheers mate!
  1. How to make your own B5 liquidA4/S4/RS4 vent pod
    By freegeek in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2009, 21:08
  2. Roll-your-own S3/RS3?
    By rachaeljf in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2006, 16:46
  3. How to make your A4 look like an S4 (easy)
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2006, 13:25
  4. make your own cat helmet, (for TDI line)
    By griffj in forum General Chat
    Last Post: 29th January 2006, 20:13
  5. Fix your own
    By MisterD in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th September 2003, 18:00
