Badger5Monster Motorsport
Results 1 to 8 of 8
    2,159
    AJM EGR delete advice
    I'm looking at removing the egr from the engine, I replaced it a couple of years ago with a new genuine unit (Got one cheep off ebay), however this has also started to leak like the old unit and I'm thinking of just remove the EGR as I just cannot see how used exhaust gas being feed back into the engine is a good thing! Have been looking at allard kits but not sure if these are a good thing or not, as I would like to remove the EGR unit
    Also would removing the EGR cause any engine management issues, don't what to have to pay to get it mapped out etc.
    Thanks for any advice.
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    I know from when I had the passat that I was told If it was early 2003 or older I could do the egr delete without it throwing back an EML
    where as on 2003 onwards it would need to be mapped or coded out via VAGCOM
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,000
    From about 2001ish, makers started putting EGR gas sensors in the EGR pipe work and soon as they stopped detecting gases it would throw an error up.
    I don't think the B5s had this sensor so you should be ok to just blank the valve.
    You can buy kits off ebay and Audi did a genuine blanking kit. There's a thread on it somewhere, I'll try and dig it out.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    2,159
    Cheers that would be great.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    I have an ajm engine tdi,I cut the egr up,welded the ends together and used a silicon pipe to replace the oem bend.If you remove the egr,you need to either block the egr and anti-shudder pipes,or do a vac line delete,which is what I did.
    if you need help with a vac line delete,I can tell you what you need to do.
    tony
    2,159
    Cheers, I was looking at one of these kits Allard 1.9 TDI EGR Delete kit Golf 90 110 TDI 115PD | eBay
    I just wonder if the golf AJM engine is the same size hoses and manifold
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Probably the same hoses etc,but doesn't a golf manifold point the wrong way?This may affect things!
    tony
    2,159
    Yes the manifold does point in a different direction but if the mount holes are the same and the pipe diameter is the same then it should fit just fine the question is about the mounting home and pipe diameter.
  1. Egr Delete Advice
    By wigandill in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th October 2013, 15:14
  2. Potential Mods: Egr delete, Short shift kit
    By jwhat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st July 2010, 13:18
  3. Allard EGR delete kit
    By TDiSPORTA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 21:55
  4. EGR Delete?
    By waqi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2010, 00:10
  5. EGR REPLACEMENT-ADVICE
    By vw754 in forum General Technical / How To
    Last Post: 13th December 2006, 11:56
