Chris NottSky Insurance
    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    Oil catch tank installation
    Im thinking of doing this on my a6 2.7t, to install, does it basically go between the nipple in the "y" pipe and the "spider hose"? as if so, i was going to make a complete new spider hose using braided hose, which would then plum into one pipe on the catch tank, then the other pipe on tank would then just go to the "y" pipe. Is that correct?
    Audi a6 2.7 bi-turbo, spax coilovers, 3SDM 19" 10j alloys, full turbo back twin exhaust with RS6 style exits, HID's, DRL's, over sized RS6 spoiler, stage 2 remap, RS4 K&N, Infinity 6x9, infinity door speakers, orion hcca 15 in custom enclosure 1 x hifonics brx2000.1 amp and 2 x hifonics brx 640.4 amps, 2 x yellow top batterys, RS4 turbos, inlet pipes, stage 2 clutch
    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    bump :-)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Before you start hacking up the spider hose, you need to understand exactly what it does. Some of its straight forwards, but theres also various check valves and other connections from Evap, N75 and other important components.
    TD5 Land Rover Defender build
    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    yeah, i guessed that when i started to look at it lol but my plan was literally to replace all the pipes, leaving all the connectors ect... but just wanted to make sure that the spider pipe goes into the tank and then a pipe comes back out of the tank into the inlet (y) pipe.... also, would i just use a sealed tank or a breather tank?
  1. Are Oil Catch Tanks Any Good?
    By S3 Vermin in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 22:49
  2. Oil catch tank on a TDi
    By Teejay in forum Diesel forum
    Last Post: 15th September 2008, 22:21
  3. Oil catch tank on a TDi
    By Teejay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2008, 17:34
  4. Any one tried fitting an oil catch tank on S3
    By 4real in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2008, 17:30
  5. Oil catch tank???
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2007, 14:52
