    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    quattro rear suspension
    Hi all.
    Had my rear springs replaced. And noticed the top part of the suspension which comes over the wheel is quite close. Is that normal? Not touching though
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    Normal !! Its the upright but id look at replacing the rear bushes as the probably shot by now !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Lol don't say that its all back together now lol.
  1. Rear suspension on my 1.8T Quattro Sport 190 Avant
    By jbee3 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th June 2013, 13:14
  2. A4 Quattro rear suspension links
    By b00zehound in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2009, 17:13
  3. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
  4. 99 2.8 Quattro - Sport suspension standard ?
    By imported_Legrath in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th August 2004, 20:07
  5. (Rear?) Suspension Knock on S3
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 19:05
