Chris NottMonster Motorsport
Results 1 to 10 of 10
    davy j's Avatar
    Jun 2013
    Edinburgh
    74
    front suspension
    how easy is it to replace the front strut on a 1996 A4?
    done the back but dont know what is involved in doing the front
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    You need to take the pinch bolt out the top of the upright, remove the three bolts holding the upper arm carrier, remove the lower shocker bolt on control arm and it should come free !!!
    2,152
    biggest problem is the pinch bolt if it's not been touched in a few years.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    Instructions here for coilovers (but includes pics) so useful. AudiWorld Tech Articles
    Get a new pinch bolt prior to starting the job. If the strut is out, I'd be temped to replace the upper control arms too.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    701
    or you can do it without touching the pinch bolt
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Aug 2010
    3,115
    Dont think the B5 has body plugs to get to the top mount !
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by Bradderz_1988 View Post
    Yes it does
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    jbh
    jbh's Avatar
    TDi lover
    701
    yea as above when I changed the front shockies on my old one that's all I did
    Aug 2010
    3,115
    Smartarse's lol Hey least ive learnt something new today !!!
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    When I took off my front struts,I undid the top 3 bolts,lower shock mount,then the 10mm nut holding the top mount to the strut and it was off.No need to touch the pinch bolt.
    tony
  1. squeky front suspension
    By misledyouth in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 12:26
  2. S3 Front Suspension/ steering
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2005, 21:59
  3. S3 Front Suspension Knock
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 12:25
  4. Front Suspension Woes (a wee bit longish)
    By IanWood in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2004, 14:04
  5. A/S3 front suspensions??
    By Drill in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2003, 14:33
