Volks AutosEM Tuning
Results 1 to 11 of 11
    audiholic ste's Avatar
    Aug 2013
    164
    a4 1.8t s2000 air filter
    Hi I'm new to this and was wondering if anyone has used or if we could use a s2000 air filter on a a4 1.8t
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    yeh i'm sure it could be made to fit
    TD5 Land Rover Defender build
    Aug 2013
    164
    Yeah but on a s3 8l it fits right on . No messing about . Straight swap .
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    The filters are cheaper enough to give it a go.
    Try it.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jun 2013
    Montrose, Tayside
    89
    I will whip the filter out my s2000 and try fit it to my tqs after work
    Aug 2013
    164
    Cheers would be very helpful of u . It's better to know .
    Jun 2013
    Montrose, Tayside
    89
    It doesn't fit, turbo intake pipe is about 15-20mm too small in diameter
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Yeah as the S2000 is 3" ours has a 2.75", the S3 lads fit the s2000 one over the maf and it will just about hold it !! you could get a 180' silicone hose that goes from 2.75" ID to a 3" ID and remove the standard airbox and make a bracket like the k&n one that bolts to the maf fixing holes and pipe your pipe off the maf ???
    Jun 2013
    Montrose, Tayside
    89
    Yeah I don't see why that wouldn't work, reducers can be picked up cheap
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    wouldn't this just breath hot air from the engine bay?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Aug 2013
    164
    Cheers lads if all I need is a reducer ( got one somewhere ) I'll give it a go . Cheaper than k and n cone filter . Just want to make the old car a bit more sprightly . I can knock the brackets up at work .
  1. Benjamins S2000 air filter mod.
    By BENJAMIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2014, 15:52
  2. Just fiitted the Honda S2000 Air Filter Mod
    By bree9482 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2013, 18:01
  3. S2000 air filter mod - problems / questions
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2013, 22:15
  4. S2000 Air Filter
    By Pubemammal in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2013, 20:10
  5. New air filter?
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2003, 08:44
