Chris NottVolks Autos
Results 1 to 1 of 1
    2.8 30v's Avatar
    Aug 2013
    berkshire
    77
    brake light warning light on
    I've checked all the bulbs all ok then if found that the high level brake light has been wired into the n/s/r brake I have disconnected the high level brake light and have no power to it I have check the wiring from the multiplug behind the n/s/r 1/4 panel trim to the high level brake light and all seams ok
    when I connect it all back up and remove the o/s/r bulb the warning light on the dash goes out has anyone got any ideas on what I can do to put the warning out or were to start looking for the fault
    the car is a 1997 b5 avant
  1. Brake Pad Warning Light?
    By K-Dash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2011, 22:23
  2. brake pad warning light
    By avanted in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 00:59
  3. brake pad warning light
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2008, 10:22
  4. Brake system warning light - ABS related?
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2008, 03:16
  5. Brake pad warning light reset???????
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2007, 08:27
