EM TuningSky Insurance
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By aragorn
Thread: 2.5 TDI Q Avant rear disc replacement
    Aug 2013
    Evening all....just bought new calipers and discs for my rear axle but I've heard somewhere there is a method to get the rear discs off without busting my b***s trying to undo the carrier hex bolts....is this true? how's it done?? Anyone got any tips??
    Thanks, much appreciated, P.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    The carrier hex bolts shouldnt be that bad to remove you can loosen the top one and remove the bottom one and iirc will come off if you lift the carrier up.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2013
    Can't shift them and don;t wanna round them off......was under the impression the hub has a small cutout to allow removal of the discs without carrier removal but damned if I can find it!!
    Aug 2010
    2,870
    What you tried to remove it with ?? Ratchet and size etc
    Aug 2013
    used 8mm hex bolt and 1/2 inch drive with breaker bar..
    Jul 2007
    London
    3,074
    Discs should come off without taking the carriers off !
    Sorry, just noticed it's in the b5 section, the discs won't come off without removing the carrier ! Get some good mole grips and loads of penetrating oil and they will come off eventually !
    FOR SALE:
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Before you go any further, go get a set of new carrier bolts from Audi, that way if you mangle them, its not a problem for refitting, and you'll be fine for next time.
    A decent 8mm hex drive socket properly hammered in, and careful application of torque should see them off, make 100% sure the torque is applied perpendicular to the bolt, and dont let the hex bit droop down at an angle when your trying to undo it, or you will chew them up.
    Worst case you cut the heads off, or if you have access to a welder, weld a M10 bolt onto the end of the cap head and undo using that..
    spartacus 68 likes this.
    TD5 Land Rover Defender build
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    244
    Spot on. If the rear of the car is jacked up (axle stands for safety) you can get 1/2 ratchet with extension and 8mm Draper hex bit on it, wire brush first and hammered in to seat. Applied pressure rather than brute force and it will shift. Also read that Irwin bolt extractor can be used if the bolt is rounded off.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Aug 2013
    Spent this morning managing to round the bolts off unsurprisingly...am gonna have to admit defeat I think and get someone with a significant heat source and ramp to have a go....
    thanks for your replies guys...good to know there are interested parties on here....will come back more often!!
  1. Rear discs and pads. 2.0 TDI 140 (2003)
    By xs2man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 10:53
  2. B6 avant cross drilled front (and rear) discs anyone???
    By mrmule in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2010, 10:20
  3. A6 Avant quattro rear discs question
    By Inskip75 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th January 2010, 05:52
  4. Rear Brake Pads & Disc Replacement
    By maddoggydawg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 20:43
  5. help on replacing rear discs
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2008, 20:40
