AH FabricationsEM Tuning
    Charlies604's Avatar
    Jul 2005
    Plymouth/Taunton
    203
    Fitting Dump Valve HELP!
    Hey all, about to purchase a Forge DV, however will i need anyhting else in order to fit it directly to the car?
    Thanks all!
    Charlie.
    Jul 2005
    2,488
    Re: Fitting Dump Valve HELP!
    I believe so, try a search. IIRC from what others have said, you fit these upside down too.
    imported_VaulterTim
    Yes indeed, I have a Forge FMDVR and their instructions clearly state to fit it in the reverse orientation to the OE valve. But as far as physically fitting it is concerned... it's simply a direct replacement. It will be much easier with the car raised since Audi have located the DV on the A4's in a crap location!
    For reference... it is at the bottom left-hand side of the engine bay as you view the car from the front. And very fiddly to get to!
    T
