EM TuningMonster Motorsport
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    1.8T oil pump ??
    Which is the correct part number for the AEB/AJL ??
    1.028115105M
    2.058115105CALT
    3.058115105C
    as my light came on again the other day after being in traffic for 5 minutes after getting off the motorway then went off as i pulled on the roundabout ?? Do you think it could be pressure switch playing up not plumed in a pressure gauge yet but thats on the list to do !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    1. is for a diesel
    2 and 3 are the same number, one just as "ALT" on the end for some reason?
    058115105C is what you need anyway.
    TD5 Land Rover Defender build
    Aug 2010
    2,866
    Cheers mate thought it was just theres a number 1 on ebay genuine audi for £40 ... Bummer !!
    why couldnt it have been a 1.8T and not a bloomin diesel one haha
    Aug 2010
    2,866
    Got my pump yesterday, now im in work tomorrow and thinking of doing it but ive got to do the rear wheel bearing that i think is goosed and also one of the rear diff seals unfortunately its the opposite side to the bearing .. Typical so ive got roughly 5 hours to do the lot now my question is how easy is the sump to do with the front end off on a 2 post ramp im thinking if it doesnt clear the subframe the ill just undo box mounts and use a jack to push the engine and gearbox up so it will clear or is it easier just dropping the frame ??
    any tips/pointers that would be of use will be great !!
    Dec 2011
    140
  1. Oil Pump Failure
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 10:29
  2. oil pump failure early warnings ?
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2006, 01:30
  3. A6 OIL PUMP...PLEASE help!!!
    By moesplace in forum Classic Audi Forum
    Last Post: 15th November 2006, 18:59
  4. oil pump fixed......turbo broken !
    By eastside_valver in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2006, 13:39
  5. Oil Pump 5 cylinder Engine
    By imported_Vinnie in forum Classic Audi Forum
    Last Post: 26th February 2005, 18:33
