AH FabricationsEM Tuning
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    635
    strange door lock issues
    right this has just started.
    when I unlock the drivers door with the key only the drivers door will unlock if I then turn the key a second time it will unlock the rest of the car.
    since its started this my rightclick wont unlock the car..
    it will lock as normal. has anyone seen this before? is this to do with a facelift thing as ive changed the doors to facelift.
    I can live with it but I would like to have my remote working.
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    Facelift's only open the drivers door of the key in the barrel not all doors iirc
    with your remote it may need coding to 'one touch opening with remote' iirc you using a three button remote ?? Have you change the CLP ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Apr 2011
    15
    Mine does something similar, if I lock it for any length of time all the indicators light up
    and subsequently flattens the battery. Then to unlock it with the key in the door I have to turn it twice, but on the
    first turn no doors unlock and on the second they all operate as normal. Mines a pfl avant
    jbh
    jbh's Avatar
    TDi lover
    635
    Quote Originally Posted by Bradderz_1988 View Post
    mines didint have remote locking as standard it has the right click add on kit on it.
  1. B6 saloon strange central locking issues.
    By Legacy87 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th March 2014, 22:05
  2. 2001 avant drivers door lock issue
    By mrnice in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st May 2013, 11:51
  3. Door lock issue
    By TwistedMind in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd April 2013, 14:12
  4. Audi A6 2001 Door Lock issues
    By paddywagon in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th September 2012, 10:14
  5. Wierd door locking issues.....
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2007, 13:01
