JMB RetrofitsVolks Autos
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    steering rack differences?
    I'm going to be changing my steering rack shortly. I've got a replacement sitting but I'm wondering if there's one I can fit with a quicker ratio?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,137
    You want the one without steering damper from a TQS/S4 after 2000 or there is an early one that has no damper which i fitted to my TQS that was light and quick but made my car understeer like mad due to the given weight and quattro !!
    theres a thread some where with part numbers of which i fitted i did this job twice and actually its not that bad of job as it seems you might struggle on your back as theres a bolt buried you have to get from underneath the car up behind where the cat is its a fidlly job that requires a wobbler and a long extension !!
  1. Steering Rack Differences
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2013, 17:59
  2. Possible Leaking Steering Rack A4 2.6 Quattro
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2005, 11:40
  3. steering rack removal
    By zirconium in forum Classic Audi Forum
    Last Post: 8th September 2004, 09:09
  4. Steering rack problem
    By mramage in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2004, 08:51
  5. Steering rack
    By GolfV5 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2004, 23:27
