Chris NottAH Fabrications
    Jan 2012
    Malton
    279
    concert iso connector
    can some more knowledgeable forumistas confirm that
    on the concert connector the circled pins are the CD player L&R pins and the ground for those pins. If I want to take a 12 v power feed off the plug for a bluetooth receiver can I use the pin marked 12v just behind the ground pin? Are the power pins all always on or are any swtched on with the ignition?
    thanks all
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,646
    would probably recommend the ones I have highlighted in Green and Red. "Ant" may only be on when the radio is on though.
    Currently rolling in a SKODA!!!
    Jan 2012
    Malton
    279
    Thanks Arrkon - when I took the radio out it had a sticker on it that showed a switched power supply which is perfect. It the second pin from the top right on the CD changer ISO plug. I grounded the transformer I was using to the radio case to avoid interference on the input from the Bluetooth receiver.
    i used a lead I got from china which was a male iso to female ISo so I could wire it all up on the desk and then try it out and TBH so that I could return it all to default mode if it didn't work. Which it does, which is good. Thanks for your reply.
  1. ISO connector, help needed
    By a3sline_nottingham in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2012, 15:04
  2. Aftermarket system with ISO connector
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2012, 09:15
  3. ISO Connectors
    By AudiiduA in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2010, 16:17
  4. ISO wiring help. Information needed. Concert CD player.
    By MiT in forum In-Car Entertainment
    Last Post: 10th April 2007, 18:11
  5. Audi Bose Concert 13pin Connector Pinouts
    By Olly__K in forum In-Car Entertainment
    Last Post: 15th February 2005, 19:21
