concert iso connector
Tom_B
Malton
Elec185 8
can some more knowledgeable forumistas confirm that
on the concert connector the circled pins are the CD player L&R pins and the ground for those pins. If I want to take a 12 v power feed off the plug for a bluetooth receiver can I use the pin marked 12v just behind the ground pin? Are the power pins all always on or are any swtched on with the ignition?
thanks all
Elec185 8
would probably recommend the ones I have highlighted in Green and Red. "Ant" may only be on when the radio is on though.
Thanks Arrkon - when I took the radio out it had a sticker on it that showed a switched power supply which is perfect. It the second pin from the top right on the CD changer ISO plug. I grounded the transformer I was using to the radio case to avoid interference on the input from the Bluetooth receiver.
i used a lead I got from china which was a male iso to female ISo so I could wire it all up on the desk and then try it out and TBH so that I could return it all to default mode if it didn't work. Which it does, which is good. Thanks for your reply.
9
889
10
2K
gmx
