Volks AutosAH Fabrications
Results 1 to 7 of 7
    Sep 2011
    Sunny Bangor. N.Wales.
    287
    help. .rear brake carrier bracket options....
    Hi all I habe an x reg 2.5tdi à4 quattro avant.and I need a rear passenger caliper carrier at the slider is stuck solid and sheared.off... what options in carriers are open to me... such as an a3, passats....etc.. as I need to ring around tomoz for the part... inless anyone off here is breaking a car where he carrier will fit.
    Many thanks
    Wayne
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    You can use any carrier from any quattro b5 only S4's have different sized rear disc's etc message sulli79 see if he has one from his TQS breaker !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jan 2012
    Malton
    272
    do you just need thebracket that the caliper mounts on?
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Aug 2010
    2,866
    Yeah so long as its from an A4 quattro not an S4, im way off ready to fit my rear 300mm upgrade otherwise id of have one !! But tbh most people will sell with calliper or in sets your best bets sulli79 or try the guy breaking the black one in sheffield iirc on ebay !!
    Jan 2012
    Malton
    272
    sorry Mackers, I just went to look at them they are the front ones not the rear
    Aug 2010
    2,866
    Lol god i need to go to bed i thought you were the OP Tom_b hence my reply at you lol
    Sep 2011
    287
    Aye its the backet the caliper bolts to with 2x13mm bolts and then they fit to the car by 2x allen key bolts
  1. Desparately need HELP, rear brake woes....
    By SpKM3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2012, 13:38
  2. S6 Rear brake caliper..help!
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2007, 13:06
  3. rear brake disc help, now
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2007, 22:12
  4. Rear Brakes help on A4
    By Lambo in forum Handling
    Last Post: 2nd March 2007, 19:11
  5. MOVED: A3t Rear Brakes....Help.....
    By richyboy in forum General Technical / How To
    Last Post: 12th June 2003, 14:43
