Volks AutosAH Fabrications
Results 1 to 7 of 7
    Jun 2012
    Essex
    55
    tapping noise from engine
    Hi,
    first of all apologies if i`m going over old ground but although i did find other posts i did`nt find anything specific to my engine.
    When i gave a friend a jump start today i noticed a tapping noise coming from either the top or possibly front of the engine that i can only hear with the bonnet open. The car is a 1998 A4 Avant 1.8 petrol.
    Sounds like tappets to me although i`m not expert! Any ideas?
    Aug 2011
    151
    Injectors?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Oil pressure or worn cam chain tensioner ???
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    635
    Quote Originally Posted by Bradderz_1988 View Post
    this would be my bet
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Sticky tappet?
    Jun 2011
    71
    I have the same tapping noise from my engine (1999 A4 1.8 tqs) a few months ago replaced the cam chain tensioner - tapping is exactly the same, so now looking at replacing oil pump in the near future, this is a major job though as I am still doing lots of research on this. Hope it cures the annoying rattle when I eventually do do it, may even do the water pump and thermostat too as people have suggested to me on here.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Quote Originally Posted by Topplumb1 View Post
    have you not tried a flush? That fixed my tqs tapping
  1. Funny noise from engine - tapping/groan
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2010, 00:31
  2. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  3. Strange S3 noise from engine
    By showyS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 08:09
  4. HELP-ticking noise from engine
    By donnylad in forum Classic Audi Forum
    Last Post: 28th August 2006, 21:08
  5. ticking noise from engine
    By chrisa4quat in forum Tuning
    Last Post: 13th September 2005, 06:34
