Results 1 to 10 of 10
Thread: Slip Rings.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Slip Rings.
    I've got a tiptronic steering wheel at home and hopefully at some point I should be getting a MFSW. I got an idea for them but before any of that I need a new slip ring.
    Got one to ETKA and it lists the following:=-
    1J0959654AG
    CANCELLING RING WITH SLIP RING AND STEERING SENSOR -esp-
    1J0959654AL
    CANCELLING RING WITH SLIP RING AND STEERING SENSOR FOR STEERING WHEEL: HEATED. -esp-
    1J0959654M
    RETURN SPRING WITH SLIP RING AND STEERING ANGLE SENSOR FOR STEERING WHEEL WITH TRIPTRONIC CONTROLS.
    4B0951543B
    RETURN SPRING WITH SLIP RING FOR MULTI-FUNCT. STEER. WHEEL FOR STEERING WHEEL HEATED.
    1J0959653C
    RETURN RING WITH SLIP RING
    The below 3 are listed again but with -ESP- listed next to them, not sure what that means.
    1J0959654AL
    1J0959654AG
    1J0959654M
    I went on eBay and was only able to find 1J0959654M (VW AUDI STEERING ANGLE SENSOR SLIP RING 1J0959654M | eBay). I assume 4B0951543B would be a better slip ring as I don't really need or care about the steering angle sensor.............Or do I?
    Looking at the slip rings on ebay for the tiptronic or MFSW options, they all appear massive, possible to big to fit?
    This is my current slipring.
    And one from ebay that's for tiptronic or MFSW.
    In short, will the larger tiptronic/MFSW slip rings fit where my bogo slip ring is?
    Would a angle sensor slip ring be of any current or future benefit to me?
    Would this be the better slip ring for me (4B0951543B) and what would the chances be of fitting a heated steering wheel?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    steering angle sensor is only for cars with ESP.
    I suspect you want the 4B0951543B one if you want to have multifunction controls and heated wheel.
    Theres just two sizes, some are big, some arent. Not sure if they're interchangable, but i'd imagine so.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Steering angle sensor not used on any thing else then?
    I can't even think what else would want that information really, so I doubt it.
    Sep 2009
    10
    Hello there,
    I have a spare (sitting in a box!) 3 spoke S/W with tiptronic paddles but my car at present has a standard wheel.
    Regarding the above part numbers, which slip ring would I need in order to use this?
    My car is an A4 (B6) cab 3.0 V6 Quattro tiptronic.
    Is there anything else I need to get, buy, code etc?
    Any help appreciated.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by a4cabrio View Post
    Hello there,
    Only just seen this, sorry for the late reply.
    Has your car got triptronic paddles at the moment?
    If not, I suspect there is more that needs to be done than just bolting it all on.
    I would suggest posting this question in the B6 section, they will know more.
    1,876
    Steering angle sensor on later models is also used by the navigation, problem your going to have is they never did MFSW & paddles on our model of car and the B6 stuff is not going to fit.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by B5NUT View Post
    I know so I'm going build one.
    MFSW + Sports trip tronic wheel = MFTTSW or something.
    1,876
    I know but I think the slip ring is going to be the problem, just not enough pins on the slip ring.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Yeah that is the biggest issue.
    BUt I am hoping I can share power cables, canbus and maybe illumination cables.
    Just looking at diagrams now to see what I can work out.
    "Stick a V8 in it!"
    14,904
    The sliprings are common to TT's A3's Golfs and various other cars, so maybe you can cast your net wider?
  1. Problems after a new slip ring
    By tdisportuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2010, 23:27
  2. New Slip Ring
    By Niknak in forum Parts Requests
    Last Post: 17th August 2009, 22:06
  3. when the airbags delploy..does the slip ring has to be changed?
    Last Post: 4th July 2009, 04:46
  4. Slip ring / Part no. request
    By sijones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2009, 18:44
  5. Right ECU/Slip-ring for cruise?
    By Von Maximo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th April 2008, 23:22
