Chris NottMonster Motorsport
Results 1 to 7 of 7
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Any one ever bought one of these?
    AUDI A4 S4 2.7L B5 V6 97-02 Bi TURBO DECAT DOWNPIPES | eBay
    The only reason i ask is i bought this (4 piece) kit AUDI S4 B5 2.7L V6 200 CELL SPORT CAT & DOWNPIPE | eBay a while back, but only came with up-pipes and cats, not with the second de-cat like above. I now want a full de-cat but dont want to buy the whole kit! so wanted to know if any one bought the above (6 piece kit) and has the 2nd de-cat pipe they want to sell. I have emailed the sellers on flea-bay but they wont sell seperatly and its pointless buying the kit again just for 2 pipes?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,116
    Think there the toyosport ones (same as xspower) lot of the srs lads run them iirc !!
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    yeah they are xs power, not bad quality for the money, mines been on a while now with no problems, its just i need the second pipes (de-cat)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    They're not cats in your first link, they're just additional silencers.
    The ones you bought do appear to be cats however.
    Why do you want to remove them? I'd imagine your best option would simply to get an exhaust shop to cut them out.
    TD5 Land Rover Defender build
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Yeah the ones i bought are 200 cel sports cats, the ones i want are just the pipes with no cats or silencers i still feel the sports cats are quite restrictive though and want to reduce lag as much as i can. I thought about cutting them out, but still need something in for the mot, thats why i thought if i could get those pipes, shorten them and weld a flange on the end of each pipe then i could just swap and change with ease for mot
    "Stick a V8 in it!"
    15,324
    well just get an exhaust shop to cut out your existing cats, add some flanges and make up a delete section. Will surely cost less than having to buy those pipes, and then still cut them up and weld flanges on...
    Personally i think your wasting your time, the difference will be marginal at best, and the hassle for the MOT test, plus the (albeit small) risk of getting it picked up on a spot check just isnt worth it for the unperceptible increase it might give.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    hmmm, i see what you mean, garage want over 300 quid to make up de-cats :-( where as a welder will charge 30 quid to just put flanges on.......
  1. any one ever seen these ?
    By gazh1234 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2011, 01:45
  2. Replies: 8
    Last Post: 31st March 2010, 18:19
  3. Has anyone bought one of these ??
    By smythey1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2010, 22:36
  4. Anyone bought one of these?
    By rosscotdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2007, 14:22
  5. Replies: 0
    Last Post: 12th January 2006, 16:46
