Monster MotorsportEM Tuning
    TED7's Avatar
    Couldn't Find Reverse Gear
    Mar 2013
    Derbyshire
    37
    Question Odd coolant temperature issue.
    Afternoon all.
    Since I got my S4 I have had a low coolant temperature on cold days (which I didn't notice when I bought it). On snowy days, the dial rarely moved above 70 degrees. If I left the car sitting still (i.e. with no air flow through the rad), it would go up to 90 and hold steady. Leaving me to believe the thermostat was stuck open.
    I have accepted this, and have been living with it.
    However, I recently discovered the diagnostic mode on the climate control panel and when I set this to 51c, which I am led to believe is engine coolant temperature, the readout starts just above ambient when I start the car, goes up slowly and after around 2 miles is 90, where it holds steady, even at 70mph (14 degrees ambient today, in rain). The dash readout didn't move from 60 until I stopped at home where it moved to 65 before I turned the engine off.
    Do B5s have 2 different sensors for coolant, one in the engine and one in the climate control heat exchanger, or does the climate control get this temp from the ECU (like it receives revs and vehicle speed) and I have a buggy dash? It may be worth noting that the DIS is also temperamental, not in the usual missing pixels way, sometimes it's just faded in patches and doesn't really light up.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    51c isnt the coolant temp, its some sort of virtual value that acts like the coolant temp but isnt. Use 49c instead.
    And yes, the B5 does have two sensors, but thats not why your 51c is reporting the wrong thing!
    TD5 Land Rover Defender build
    TED7's Avatar
    Mar 2013
    Derbyshire
    37
    Ha! That's not what I wanted to hear but thanks anyway. 49c follows the dial +/- a bit.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    i had same problem, if driving along temp gauge would hardley move then if im sat at lights temp gauge would creep up....... changed thermostat and problem was fixed
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
  1. Coolant Temperature Guage
    By filipharvey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd May 2008, 21:58
  2. Odd phone prep issue
    By consilio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2008, 23:36
  3. coolant temperature sensor problem.
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2008, 15:10
  4. G62 Coolant Temperature Sender - Replacement guide
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2007, 20:40
  5. trouble code coolant temperature below normal?
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 05:36
