JMB RetrofitsBadger5
Results 1 to 22 of 22
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Brake pads, which ones ??
    Right im on mintex red box at the minute and because everyone runs ferodo pads (well not everyone) but seen as im going big brakes i thought il give them a try instead of mintex so im after some advice for part numbers for ferodo pads as im going to order them through work tomorrow ......
    for the fronts im going B6 S4 345mm (just paid £180 for a set of calipers delivered) the original source wasnt replying to me guess he probably seen the two sets on ebay for £300+ lol so a new guy breaking one on ebay dealt with me at same price so happy days (so may have to get the B6 S4 alloys off him instead aswell lol)
    Heres what i found for the Front pads - ferodo premiers - FDB1629
    Rears will be 300mm with facelift S4 calipers and trig brackets (just need to replace a piston boot on one but doing both including the seals)
    Heres what i found for the Rear pads - ferodo premiers (choice of 2) - FDB222 or FDB1788
    Also i know that B5 S4 wheels go over this brake setup (not to sure if its with or without spacers) do you reckon the 8J boleros will go over or am i living in a dream land lol
    Jun 2013
    Montrose, Tayside
    89
    I run the ferodo ds2500 pads on my s2000 now, had them on a few of my old cars too, they bite really well from cold and I've yet to suffer brake fade from them so I rate them very highly, would suggest using a good quality disc that isn't drilled or grooved, brembo or stop tech are good
    Aug 2010
    3,136
    Im going to run ferodo premiers with mintex discs. Should be ok for daily use and a bit of hard driving.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,086
    I use Brembo discs and pads from nextdaybrakes.co.uk, even with track work I have been very pleased for a budget pad. I wasn't able to find a listing for the DS2500's for the A4 when I looked . My brother uses Performance Friction pads on his M3 and they seem to work very well indeed
    Life begins at 140mph
    www.passionford.com
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Ds's are awesomes.
    That was a cheap deal Brad. I need discs for my RS4 setup so am wondering whether to go this way
    Aug 2010
    3,136
    Quote Originally Posted by Byzan Pics View Post
    Ds's are awesomes.
    il give you the sellers ebay name and email for the one who didnt answer me if you do as he wanted £190 delivered !!
    Apr 2004
    12,520
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Ferodo Premiers are a good choice for a road pad.
    TD5 Land Rover Defender build
    Aug 2010
    3,136
    pm'd you details mark !!
    Aug 2010
    3,136
    Can someone confirm these before i order them ??
    Fronts FDB1629 and rear FDB1788
    "Stick a V8 in it!"
    15,372
    Fronts are correct for B6 S4 calipers
    Rears are correct for the aluminium rear calipers on facelift B5 S4's. Iron rear calipers use the FDB222.
    Aug 2010
    3,136
    Cheers for that yeah just wanted to double check, i kind of gathered the FBD222 were for the other type as when looking at pictures the spring is higher up on the pad backing !
    Aug 2010
    3,136
    Anyone no if B6 rear brake hoses (banjo fittings) will fit the facelift S4 rear calipers or is the thread size different ??
    As im looking at buying a set of HEL brake lines but just want to make sure ??
    "Stick a V8 in it!"
    15,372
    At a guess, B6 are M12 and B5 are M10...
    Not only that, but the lengths will be totally different as the B6 rear end is completely different to a B5.
    Aug 2010
    3,136
    Bummer .... Need some custom lines then
    Or what are my options ??
    Aug 2010
    3,136
    If i get in touch with HEL do i need facelift S4 rear lines with M10 banjo fittings or RS4 rear lines with M10 banjo fittings ???
    i might just email goodridge so there the same as whats on now !!
    Jun 2013
    Montrose, Tayside
    89
    Gerry at performancetek in Glasgow makes hel lines, he can supply any length and fitting that you need and is quite cheap, just tell him the length and fittings you need
    Aug 2010
    3,136
    Good to know !! How do i contact him ??
    Jun 2013
    Montrose, Tayside
    89
    Aug 2010
    3,136
    Eurocarparts specs
    For my car -
    Length [m] 320
    Length [mm] 295, 296, 320
    Overall Length [mm] 295
    Thread Measurement 1 M10x1, M10x1
    internalThread Measurement 2 M10x1, M10x1
    internalWeight [g] 89
    Fitting Position Front Left & Right
    Fitted Quantity 1
    PR Number 1AH / 1AR
    for s4 B6
    Inner Thread 1 [mm] M10x1
    Inner Thread 2 [mm] M10x1
    Length [m] 330
    Length [mm] 305
    Overall Length [mm] 305
    Spanner Size 15,5
    Weight [g] 95
    Fitted Quantity 1
    Now when i gave goodridge my specs i gave them this -
    Front: ~330mm with 2x Female ends
    Rear-Subframe to Wishbone: ~190mm with 2x Female ends
    Rear-Wishbone to Caliper: ~255mm with 1x Male and 1x Female ends
    so im thinking now i will just need to get some rear wishbone to caliper hoses made as above but with M10 20 degree kinked banjo fittings and i should be good to go !!!
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    I've found the new compound EBC yellow stuff pads to be a really good all rounder pad on my other cars. Prob a bit late but thought it was worth a mention
    Aug 2010
    3,136
    Not got pads yet but feroddo premiers are £30 a set on ebay and seem to be a good road pad so to save the pennies il be going with them !! But cheers for the advice !!
  1. Brake upgrade... which one should I go for?!
    By kinson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2011, 02:06
  2. Time to replace discs/pads which ones on A4 V6?
    By wellhouse0 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd August 2010, 23:35
  3. Rear Brake Pads - which brand
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2008, 09:14
  4. 312mm front brake discs - which ones?
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2006, 16:14
  5. Brake Pads - Which are your favorite?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2004, 09:49
