Chris NottJMB Retrofits
Results 1 to 10 of 10
    Mar 2010
    125
    Washer Bottle Pumps
    Another job on my Car seen as the engine is out, is fix a leak on my wash bottle, in doing so i also see i have 2 pumps, one halway down into the bottle and the other below at almost the bottom, can somebody tell me which pump is for what please as i noticed the top one is rusty and has a split
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Don't know if the S4 I's the same but on my facelift A4 the lower pump nearest the front is the headlight washer and the other is windscreen.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Isnt the lowest one for the screen and the one half way up for the headlights ??
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Maybe mine have been swapped about because the lower one deffo goes to the headlights, but it would make more sense the other way round
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Mar 2010
    125
    but basically we are saying headlights and Front screen then? my headlight washers dont work, so i am guessing thats the middle one as that pump looks totally foooooked!!
    Mar 2010
    125
    my next question is can i use an A4 one on a S4?
    Mar 2010
    125
    Oh and also are the Headlight and the windscreen the same type of pump? , sorry for all the noob questions
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    I think the pumps are different as I'm almost certain the windscreen one does the level too. But should be the same between a4/s4
    Aug 2010
    3,138
    The level sensor is seperate and is on the side of the bottle, but id expect the headlight one to have a higher pressure out put to engage the actual headlight washer ?? May be wrong though !!
    nogmeg's Avatar
    Jul 2012
    Raveningham, Norwich
    34
    Lower pump is the headlight pump, upper one is windscreen and both pumps are different.
    just replaced mine recently.
    1998 Audi S4 Avant Nogaro Blue
    Mazda Eunos roadster Mk1
  1. Gaining access to washer bottle/pump
    By bambam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2010, 21:29
  2. S4 windscreen-washer-bottle leak.
    By Dan Gliballs in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2007, 15:47
  3. Washer bottle leak.
    By Faulty in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2006, 00:33
  4. Alloy washer bottle cap..?
    By Peloton in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2006, 14:50
  5. Leaking Windscreen Washer Bottle......
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2005, 15:09
