Chris NottMonster Motorsport
    Dec 2010
    38
    Reading fault codes on Audi B5 avant?
    I've just bought myself a facelift B5 Audi A4 tdi avant. I missed my old B6 as far as practicality went, and the B5 ticks lots of boxes, as well as not having too much $$ tied up in it.
    Anyway, cutting to the chase, it's a pretty good car, with the exception of the alarm! After lots of googling, it looks likely to be the tailgate latch sensor, which is apparently quite common with them.
    I bought one of these for the mk2 a while back (when the mk2 Golf VR6 was mis-behaving), but didn't end up using it due to lack of obd2 port!
    U281 VW Audi Skoda Seat VAG CAN BUS Fault Code Reader Scanner diagnostic tool UK | eBay
    I've plugged it into the Audi; there are 5 main menus: Diagnostic Trouble Codes (DTCs) of Engine, ABS, Airbags and Automatic Transmission. I'm assuming it won't help me whatsoever with electrics then?
    Also what's the idea of Vagcom? I assume the scanner above is supposed to give fault codes, and Vagcom erases them/ gives the user options to tweak settings?
    On their 'site, they list about a million choices:
    I'm at a loss! All I want to do is pinpoint the fault, which I'm hoping is the tailgate latch...
    Jun 2011
    Great Melton Norfolk
    1,340
    If you look in the vcds users section ,find someone near your location who could scan it for you . (cheaper option)
    or buy a cable from Nigel (NHN) on here if you want full diagnostics. He will tell you the best option.
    Dec 2010
    38
    Thanks, will go have a nosey!
    Dec 2010
    38
    Riiiight, update time. I eventually got a Vagcom cable, finally got the interface connected, and now the software crashes each time I try to scan. I'm running Vista, and a quick google suggests it's not the best combination....
    In the meantime, I've noticed the luggage compartment roof light doesn't work, even with new bulbs, with the switch in any position.
    So, I can't run vagcom, and I'm still no closer to solving this alarm problem.
    Any other suggestions?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Take the latch apart and check/clean the contacts on the micro switch?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    May 2012
    RETFORD, NOTTS
    1,712
    no lights = no power/blown fuse iffy wiring?
    Where are you based?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. fault code P0171 audi a3 1.8t
    By ricardo33 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2012, 23:17
  2. Fault Code 01271 Audi S3 8L
    By LordNelson in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th November 2009, 16:27
  3. can you read fault codes at home?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2008, 09:31
  4. Removing Fault Codes on Audi 80
    By Spoon in forum General Technical / How To
    Last Post: 18th August 2008, 17:44
  5. Fault code on Audi S3 Central locking
    By jesters3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd September 2007, 20:37
