Monster MotorsportEM Tuning
    1,877
    Sanding B5 body panels
    Looking for some advice on sanding down body panels, and just wondered if there is anyone on here with bodyshop experience. There is no damage to the panels it's just someone has down a pi$$ poor job on them before, it looks like they were done with a rattle can and a blindfold! Do I go down the bare metal or just take the top paint off? Also whAt do you recommend to sand the panels down with.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    If its all smooth and no flakey paint, a reasonably aggressive scotchbrite pad should be enough. Are you painting it yourself? If not ask the bodyshop doing the work some are pretty helpful with the advise if you doing your own prep to reduce costs.
    also I reckon YouTube will have stacks of how to vids
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    All you need to do is as above use a scotch pad till its to a matte look finish with no laquer visible (no shine at all) use panel wipes to get rid off the crap and if theres any deep chips, sand with 1000 grit paper till almost smooth then finish of with 2000 grit but go over that area so its levelled out in that area !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    1,877
    I'm doing it myself, I've painted a few panels but they have been new. Just wondered if I should take it back to metal, or just take the top coat off. Also what is the best machine to do the sanding, I have a 150 litre compressor, which I mainly use for blasting & painting.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    I haven't done much myself but I have found that doing it by hand was better for me as with a machine I took too much off on curved areas.
    I wouldn't personally go to bare metal unless treating rust
  1. Left rear body panel removal
    By DragonHawk in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2012, 11:39
  2. CARBON FIBRE BODY PANELS 8L
    By Don's A3 TTu in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2011, 19:24
  3. Where to buy body panels
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2009, 15:20
  4. body panels etc
    By colin.t in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2009, 00:57
