EM TuningMonster Motorsport
    2,158
    PAS Pumps do they fail?
    At the moment I've got the front-end of the car striped, Just done a bunch of work including the engine & gearbox mounts, cam belt, water pump, gearbox oil, pas fluid change, viscus fan, alternator..... So my question is what are the pas pumps like on these cars when they reach 13 years & over 200K miles, are they prone to fail? I hope not to take the front-end back off the car for the next 2-3 years until the belt needs to be done again, but the car will then be 15 years old with 260K on the clock... Not sure what to do.
    The car is a 2000 model 1.9TDi PD engine.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    tbh anything can fail. Not a normal / known fail point
    2,158
    Yep, anything can fail, just wondering if it was a known failure point on older models.
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    Ive only ever came across 1 power steering pump that has failed.
    and Ive worked on cars and in garages for over 20 years
    check around it for leaks if you cant see any build the front end back up and don't worry about it.
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Pumps normally fail due to internal wear of the rack and swarf circling back to the pump then it buggers the pump, for piece of mind replace it because now you've mentioned it sods law will only be around the corner !!
    2,158
    I'm changing the PAS fluid and will give it a flush as the stuff that dropped out was just about black!
  1. Noisy PAS pump?
    By Dicky A in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2013, 17:43
  2. Rattle noise from PAS pump area
    By Slimg60 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st August 2011, 21:18
  3. Just changed PAS pump
    By bucks_a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2009, 19:14
  4. Possible to change PAS pump without service position?
    Last Post: 18th October 2009, 13:31
  5. Droplinks - how long til they fail ?
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:34
