Chris NottBadger5
    Mar 2010
    125
    Turbo Removal Guide
    Anybody have a guide or how i remove the Turbos please (in the right order for bolts etc) , My engine is now out, and i am ready to remove turbos but some bolts look hard to access etc, so i was wondering if there is a guide on how to so this correctly.
    thanks in advance
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    You tried searching google ??
    if the engines out id say theres no real order just have a good look then take of whats in the way id say downpipes/cats and boost/inlet/oil/coolant pipework first then turbos then manifolds if there coming off !
    Mar 2010
    125
    yeah google hasnt been very helpful, but thanks for the input, i just didnt want to remove things that i maybe didnt need to
    Aug 2010
    3,115
    If its out and your not in a rush just take whatever off with in reason and just remember to put it back in right place and bag bolts and label them instead of throwing them all in a pile if its going to be out for a while !!
  1. Sai removal guide
    By jonny87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4 Weeks Ago, 20:52
  2. S3 turbo removal - help
    By frenno in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2009, 08:13
  3. 1.8T AEB 1996 Turbo removal - how long to do
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2009, 20:37
  4. Door mirror removal guide?
    By pdv40 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2009, 17:32
  5. S3 Wishbone Removal Guide?
    By Lovegroover in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2009, 09:47
