EM TuningJMB Retrofits
Results 1 to 7 of 7
Thread: Rocking Chair !
    Jul 2005
    Glasgow
    19
    Rocking Chair !
    I'm relatively new to the forum. I had about 10 posts which were wiped, so Hello again to all of you.
    I've got an '00 W plate 1.8 TQS which I'm well chuffed with.
    I've got one problem (apart from some peeling paint at the bootlid which I posted on a while back). My drivers seat rocks back slightly. The whole seat pivots a couple of degrees. The movement seems to come from the bracket at the front of the seat (in the middle) between the seat and the floor. It lifts about 3-4mm here, which results in about 15mm movement at the headrest if I lean back into the seat. Has anyone else had a similar problem?
    The bracket at the front of the seat looks like some sort of clip that could be prised off. Do I just need to replace this?
    Any help is appreciated.
    Alan
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,849
    Re: Rocking Chair !
    Yeh there's like a white looking gromit thing that fits on there taking up the slack should be quite cheap from a dealer.
    Think the part number is 435 881 203A
    Jul 2005
    Glasgow
    19
    Re: Rocking Chair !
    Thanks Docurley
    Alan
    Jul 2005
    Glasgow
    19
    Re: Rocking Chair !
    Result - phoned Glasgow Audi who advised the cost for that part no. is 2.23 .
    Anito's Avatar
    Dec 2003
    Chester
    429
    Re: Rocking Chair !
    I have the same problem. Can you let me have the part number?
    Jul 2005
    Glasgow
    19
    Re: Rocking Chair !
    [ QUOTE ]
    [/ QUOTE ]
    Docurley quoted it above.
    Alan
    Anito's Avatar
    Dec 2003
    Chester
    429
    Re: Rocking Chair !
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Alan
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/blush.gif[/img]
