Sky InsuranceAH Fabrications
Like Tree1Likes
  • 1 Post By Jonion
Thread: Spark plug Q's
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    Spark plug Q's
    Will any of these fit my car they are
    New genuine smart plugs (two prongs) - NGK bkre6ek
    or i have some genuine astra VXR platinums (used 30k) which are - NGK PFR6T-G
    obviously they will need gaping to 0.32 iirc
    just thinking of changing the plugs for something a little better
    side by side two my old ones there correct thread and length so i shouldnt see why not !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,918
    Platinums are a waste of time, the only thing they do is give you a longer service interval. imho the additional cost over a stock plug just makes them unviable.
    Euro's always try and sell me the platinum plug for my engine but I always give them the NGK BKR6E (iirc) number and get a set of 4 for under a tenner.
    Sure I was recomended a colder plug for a tweeked engine but can't for the life of me recall the part number. I have a set in my kitchen drawer so will get the numbers off them when I get home
    Life begins at 140mph
    www.passionford.com
    Aug 2010
    2,873
    Im running the bkr6e's at the minute
    just have some plugs in my box at work that are identical in thread/length etc just one set has two prongs and the others are platinum !!
    just wandering which would be the best plugs to use !!
    May 2010
    194
    Quote Originally Posted by Oranoco View Post
    If they're NGKs as well the next colder plug would be a 7 so BKR7E
    And I agree, using fancier/costlier plugs isn't my choice unless the yare required for the type of use they'll be getting.
    For a normal(ish) road car the standard NGKs are plenty good enough.
    Arrkon likes this.
  1. spark plugs
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 17:02
  2. Spark Plugs
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 19:23
  3. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  4. spark plugs....???????.....
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 17:33
  5. spark plugs
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2004, 01:23
