Sky InsuranceBadger5
Results 1 to 12 of 12
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    1.8t turbo chatter
    My QTS has developed turbochatter/ a dump valve sound on lift off. I know that these engines aren't meant to sound like this so what could be causing it? Worn Diverter valve?
    The car is feeling slow also, not sure if it's connected though as could be another issue.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    split dv, or vac pipe
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    ^^ as above
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Cheers. What dv should I fit if mine has failed? oem or an aftermarket unit?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    Standard 710 iirc from Audi from the 225 BAM engine or Forge 007 if you want aftermarket.
    Life begins at 140mph
    www.passionford.com
    Aug 2010
    3,138
    Yep forge 007p i run this some say they leak and spit the seal but mines fine and running great !!
    or you could get the new revised 008 !!
    Apr 2004
    12,522
    007/008 waste of money. I have a revised 007 on mine, no leaky, but only cos it was fitted when i bought it. I'd go OEM given they are £30 and last 10 yrs or more and hold up to 2 bar perfectly
    Aug 2010
    3,138
    Think mines the 007p from awesome GTI is that the revised version ??
    Apr 2004
    12,522
    Quote Originally Posted by Bradderz_1988 View Post
    only if it's under about 4 mnths old, otherwise contact Forge for the revised piston kit. I had mine for free no questions asked.
    Aug 2010
    3,138
    Quote Originally Posted by Byzan Pics View Post
    i bought it end of 2011 iirc
    will contact forge see what they see, how did you get it for free ??
    Mine looks like the piston in tge top right ???
    FORGE MOTORSPORT DUMP / BOV VALVE SERVICE KIT FMCL007P / 006 / FMFSITVR / + MORE | eBay
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Oem seems to be the way forward then. Cheers guys.
    jcb
    Sep 2005
    uk
    4,077
    I think the Forge one is a decent option, expensive bit of bling but i always prefer metal over plastic.
    the placcy one I had introduced a bit of hesitancy responding to quick decel/overrun - acceleration
    never had that in 8 years of 007 ownership
  1. Turbo chatter
    By shanejess in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2013, 18:34
  2. Turbo chatter
    By Conorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2012, 21:58
  3. Turbo Chatter
    By sam4191 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2011, 19:53
  4. Another turbo chatter question
    By paulsaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2011, 20:17
  5. Turbo chatter at low revs, DV fault TFSi?
    By S-Liner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th June 2011, 19:02
