Volks AutosEM Tuning
Results 1 to 16 of 16
    Jun 2012
    Ireland
    59
    CV boot quality question
    I discovered that my driver side cv boot is ripped and cv joint is exposed (2WD). I was wondering is there particular name of cv boot maker i should go for cause friend of mine got 2 new cv joints and boots fitted about 3 months ago and cv boot is ripped in half on both sides. I dont whant to have same problem.Should i buy it from Audi dealers cause i had bad experience with parts from local motor factors. Thanks.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    I would always use genuine audi boots. Some others can be a poor fit.
    A4 1.8T Quattro
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Febi bilstien from ebay seller stephenj65 iirc get the oem part number and message him if he doesnt have the ones you want listed and he will get them and there next day delivery when they arrive with him !!
    ill have a look see if theres one for yours !!
    Aug 2010
    3,136
    Jul 2012
    Guildford
    97
    Just bought genuine audi today, over twice the price of the factors boot but they could not get one in until Tuesday. Factors boot comes with a bolt, Audis does not and its £12 extra making an Audi boot 3 times the cost, will it last 3 times loger?
    jcb
    Sep 2005
    uk
    4,077
    no it won't!!
    I got decent rubber factor ones
    learnt my lesson getting EuroCarParts ones that felt like washing up tubs!.
    didnt split but so fecking hard they pop off every time!
    griswold's Avatar
    340
    Euros sell a few different ones, I got a lucas one from them recently but had an audi strap fitted, the audi boot was almost 3x the price.
    The other side had full cv joint and boot replaced before, that was a q drive brand fitted a while ago the tech inspected the boot was happy just binned the strap still going strong.
    Some parts worth spending a few quid more on (lemforder) but some smaller stuff worth a gamble.
    How many of us use bkr6ek plugs £8 instead of audi platinum ££££.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Aug 2010
    3,136
    I use bkr6ek iirc
    Does any one no if you can use bkr6eke with two prongs instead of one ?? Just have a set of them so may use them when ready for replacing my old ones.
    also i bought 2x front cv boots from the seller above for £36 delivered and are the hard plastic type with the correct heavy duty clips a twat to fit but are not budging !!
    Jun 2012
    Ireland
    59
    Just ordered febi on ebay so I will see the quality when its fitted. On passenger side i fitted unknown maker cv boot and rubber is quite hard and it was really hard to fit it but as long as it last i dont mind.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    I've recently fitted a new GKN driveshaft joint to my car and the boot was of the soft-rubber type that was fitted fairly easily; its a simple job to crimp up the metal clips to secure the boot in place....
    I've also got a spare Genuine boot kit here that is of the much harder plastic variety, fearful of not being able to get the metal securing clip up tight enough I chose not to use it but use the GKN boot instead...
    Time will tell if I've made the right choice but I have found that the harder plastic Genuine boots do appear to last longer, they are just a pain to fit as they want to pop off the joint unless you get the clips really tight.....
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Quote Originally Posted by Nessy View Post
    I used to buy GKN driveline boots, and rate the kits, including decent metal clips. However I noticed the boots develop cracks after a couple of years. Check periodically and avoid hard lock steering where possible.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Jun 2012
    Ireland
    59
    just got it fitted today and pretty happy with the boot it was quite hard to get it on the cv joint. rubber is quite hard so it should last longer.
    Aug 2010
    3,136
    Which did you go for ??
    Jun 2012
    Ireland
    59
    febi bilstein from ebay.
    Aug 2010
    3,136
    Yeah there a bit off a pain to get the boot on the joint with the clip inplace but once there tight they should be good for a couple of years at least !!
    you used the correct tool to tighten them i presume as they would of popped off by now lol
    Jun 2012
    Ireland
    59
    i did i wouldnt take a chance lol
  1. RS4 avant boot spoiler question
    By OllyS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th September 2009, 19:27
  2. new owner with questions to boot....
    By dstructiv in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2009, 16:25
  3. boot question
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2009, 21:53
  4. boot swap questions
    By joss in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th July 2008, 08:43
  5. Amp in boot RCA lead question
    By imported_kenloen in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2005, 17:34
